One thing I hate about winter and e-biking is the cold. I commute every day back and forth to work for a total of about 12 miles a day. Although it does not snow in South Louisiana often but it does get down into the teens and 20's fairly often throughout the winter. Another thing about below 70 degree weather is battery performance. I notice the decreased lack of range and speed especially below 60 degrees. Not sure how everyone deals with this in the northern climates where it snows a lot but I came up with a solution that I am going to test out in the next couple weeks. After some research I ended up convincing myself to order some low-voltage carbon-fiber heating pads. They run off a 5v/2a 18650 rechargeable battery pack. I figure I will sew a couple pads into an insulated blanket/wrap and then wrap this thing around my down-tube battery. I found one with a 3/way power setting so I can adjust it according to the temperature outside. I figure if I can keep the battery about 70-75 degrees that will be perfect.
I also found a 5-pad set designed for heated jackets, vests, etc. on ebay for less than $10. Riding at 20-30mph in 30 degree weather need not be this cold. Thoughts, suggestions anyone? Thanks!
