Chuck E. Cheese
The Supernova light on my ST2 is insufficient for where I ride. I need something with a wider beam and a longer throw, preferably with a cutoff focus to avoid blinding oncoming traffic. I'm looking at the Seca 1800 which looks like it would do a better job, but without disassembling the bike I don't know how to wire it. Does anyone know if the OEM Supernova E3 uses the same connector as the Seca or whether it is soldered directly to the motherboard? Would I be better off just snipping the existing wire from the Supernova and splicing the wire from the Seca to it? I have a ton of soldering experience and am confident I could make a clean, waterproof splice, but I'd rather not cut the wire if it's not necessary. I read somewhere that the OEM light runs off a 6V rail. It's hard to find other well-reviewed lights that operate at that voltage. Most seem to be either 12V or higher. Any suggestions would be appreciated.
