I have read the issues of changing the hub gear in a Sondors Fold XS bike. Changing the high gear as referenced by a forum member has caused slight rubbing on the frame. Has anyone changed the crankshaft gear instead of the hub gear?
If so, what size (tooth) gear could I use without having to get a longer chain? I am trying to solve the problem of "running out of pedal" when I am in level 2 and 3 of PAS. If this can be done, could someone reference where to purchase. Thank you!
