bellandbottle
- United Kingdom
Well done.
Did you use Loctite blue for the chainring bolts?
I believe that I missed it on one of them when I first mounted them, and lost a bolt two weeks ago.
So I tried to fasten a new 2-piece-set chainringbolt without taking the spider off. Never again I must say.
As I had pointed out in #47, the chainringbolts for the Deckas are to be held from the back which is almost impossible without taking the spider off.
The chainring bolts I used in the end were a bit long, so I fitted them and filed them back to the sleeve nut, then unscrewed them 2/3rds of the way, put loctite blue on the threads, and tightened them up again.
By the way, I had to put 8 more links onto my chain whip to hold the chainring and spider when I torqued up the ring - the video was great for that, 18 minutes in.
Thanks again for your help
