Burnt to a Crisp: Name and Fame for E-Bikes Aflame (Open Thread of E-Bike Fires)
The ones you linked to. I don’t see where they say they are for lithium ion charging. I saw the designation when looking at 12v chargers. Some were for SLA and some for lithium ion. Is the real difference only in output voltage of the charger? I know 12v SLA and 12v l-ion charge to different voltages. Other than current, since that is also adjustable in your linked chargers, is that the only difference? Seems like yours are just power supplies and not a designated charger. Maybe they can be the same, as long as they are set properly?
This is where things COULD get dodgy. If you poke around the world of eBike forums and come to know the trusted sources you'll find these Meanwell power supplies are safe for our chemistry, reliable, and used by many. Where things go south it's usually because of some boob on YouTube or on a forum draws crazy conclusions and strikes out on their own and tries to use some other product or variation. OR is a truly goofy user that doesn't put his multimeter to good use.
You're safe with the Meanwell listed.
We're told to use only the manufacturer charger because very many are confused about what the LVC, low voltage cutoff, nominal charge, and finished charge levels are.
For example, a 48V battery fully charged is 54.6V. A 52V battery 58.8. And those are HARD maximums to NEVER exceed. Yet someone will read that some cells can be charged to 4.3V and THAT is where things begin to fall apart...
This explanation was very helpful. Thank you. It mirrors the warmth of a charger. It peeks then backs off. Makes sense.
Yes. When calculating how many amps you can set a charger for, you don't calc max voltage times max amps, since the CV mode will start paring back the amps before you reach the voltage target. This will also slow down the charge-per-hour since you won't be feeding full amps into the unit for the last ... 45 minutes? of the charge operation. But even with all of these fudge factors, its still way better than just plugging in and coming back 3 hours later to see if the red light is green now.
A bike came to my workshop and I looked it over outside. It had water incursion into the cells with lithium crystals growing out the discharge port. The guy left the bike before I spotted the problem. The battery is now outside under an upside down steel wheelbarrow. Until he can collect it. But that could be a problem. I heard the house where he lived caught fire and one guy died. The repairs including the new HQ battery added up. https://www.petaluma360.com/article...tify-man-who-died-during-petaluma-house-fire/
Edit:
Here is what that bike looks like now. It was the very worst mess of wires and connectors. The drive train was shot. It didn't shift. The pedals were junk. The brakes didn't work. The controls were unattached. I installed the new battery and fixed everything.
Any recognizable brands before the fire or can't tell?
Specialized and Ancheer have had bikes catch fire but both issued recalls. These are worth noting but it's far more concerning when a manufacturer does not issue a recall, because then a) owners are left with a potentially defective dangerous product and b) no one knows the product is at risk
Also the Specialized recall was much narrower than the Ancheer one, a problem limited to a few specific models, vs apparently a wide array of Ancheer models.
