Solliex
Can you please clarify “means loss of manual pedaling low gearing“? Do you mean when pedaling without assist? Or?
What I mean is that when the unit is put in overdrive the lowest gear is not as low as it was before when it was not in overdrive. Overdrive simply shifts the range of gears, it would be like going from a 42 tooth front sprocket to say a 52 tooth one. So if I was paddling without any power going up the big hill I would rather have a 42 tooth front sprocket then a 52 tooth one. But that means you will not have as much top end at a given speed and your cadence will be much higher as well. So in order to achieve 28 miles an hour you have to go with the overdrive or in my example the 52 tooth front sprocket. I hope this story clears up what I meant to say.
