AHicks
- USA
- City
- Snow Bird - Summer S.E. Michigan, Winter Gulf Coast North Central Fl.
Guys, new issue starting on my fairly new Ultra powered Rize RX Pro at 150 miles or so. The RH crank arm is making noise, and when checked, the attaching bolt will be loose. When tightened, it will start making noise again within just a few miles. I've marked the bolt to see if it was unscrewing and it is not. This has to be a failure of some sort. At about 175 miles, I've tightened it 4 times, and this last ride it only made it a couple of miles before starting the clicking again.
Tonight I've done some homework, and it appears that this is not the first time the problem has surfaced. Less clear is the permanent solution. I can buy replacement Bafang (or more likley, knock offs) crank arms on Amazon, but the question is, will I be throwing good money after bad?
Thomas offered an opinion regarding Lekkie Buzz Bars in a post a few years ago. I located a set of those at EM3EV, but they're 90 bucks (Amazon was 22.)!
Any experience you'd like to share?
Thanks! -Al
Thanks! -Al
