Bafang motor pinion problem solved,"I hope". Sheared 3 teeth on my 48v midi motor after approx.600 miles, stripped it down and changed it with the help of you tube,not difficult at a cost of £17 from greenbikekit,the reason I think this happened is because i was changing gear whilst motor running and pedalling hard causing a sharp snatch in the gears.
Could this be the cause?,anyone else had this problem,or shed any light on it. Pitmogie.
