Ken, it wasn't the amount of power I was referring to, it was the type of power (hub vs. mid drive). You were commenting regarding the complexity of the PAS system. Not knowing you were talking about a mid drive, my comment to you (and I think others may have been thinking along the same lines) was regarding the extreme simplicity of a PAS system - as used on a hub drive system. From a practical standpoint, they're no more complex than a headlight. Mid-drive is obviously a whole different story.
And after using a PAS system since I started riding e-bikes, the throttle seems a very strange sort of compromise when compared to a functional PAS system, especially one tuned to your riding style (using a tuneable controller, like Bolton's for instance). A throttle does though, have some features I would miss if it were not installed. My bikes will have both, no doubt. -Al
Actually I didn't wan to differentiate between hub and mid-drives but most mid-drives have integrated torque and cadence sensors so we are unlikely to see any throttle only assist mid-drive ebikes. I believe that throttle only does make a lot of sense on geared or DD hub drive ebikes because in reality a throttle is just an infinitely variable assist control and some are programmed that if not moved they act as cruise control but that typically requires e-brake cutoff and I don't even want the added complexity of e-brakes.
I guess maybe the question should be. If all factors are considered (complexity, reliability, performance, etc.) which assist system would you pick if you could only have one on the ebike. A throttle only or PAS only?
Again....I'm mainly interested in ebikes as a tool for real transportation so that should be considered when answer the question.
