GuruUno
Set 2071mm - Actual 2217.71mm --- 27.5 x 2.4
www.bikecalc.com
![www.bikecalc.com](https://www.bikecalc.com/resources/media/images/tire-circumferences.png)
Tire Circumferences | BikeCalc
![www.bikecalc.com](https://www.bikecalc.com/resources/media/images/favicon.png)
No that does not work.They accounted for it so the speed will end up cutting out slightly sooner. I tried that many moons ago before I got the Bikespeed.I think they did that because people were bypassing the speed limiter by putting in a smaller circumference to make it look like they were going a lot slower than they really were.
Not true I can do it on an Intuvia,but you say cannot do it on an Allant? Too bad I suppose but what does it really matter ?Only a dealer can change the wheel circumference on a Bosch system. And even then, they can only adjust +/-5%.
Well how much is it off by?There is a narrow range of circumference settings available to the rider through both the Intuvia and the Nyon. The issue with the Allant 9.9 is that the available range is too small to accommodate the size of the tires that come on the bike. That is not something for Bosch to adjust. It is a setting that Trek controls. There are two guys at Trek HQ reachable only through Trek service network. who can get into your system through. the dealer shop. With coivd 19 there can be delays but it can get done.
upper limit was 2-3 cm shortWell how much is it off by?
So off by as much as 10 % ...yeah that is too much even for me.upper limit was 2-3 cm short
Not nearly so much Steve. A 27.5 x 2.4 tire measures approximately 88.6" circumference. That is more like 3 percent.So off by as much as 10 % ...yeah that is too much even for me.
OH yes according to Guru's calculater 27.5 x 2.35 is 221 cm ,so possiblly off by only 1 % ? Now that is not much to get excited about.Not nearly so much Steve. A 27.5 x 2.4 tire measures approximately 88.6" circumference. That is more like 3 percent.
I appreciate that but expressed as a % would I be incorrect in calculating it would be only 1.12 % ?2.5 cm is one inch which is how far off it was from a target of 88.6 inches (225cm). I don't want my speed or distance traveled to be shortchanged at all, if possible.
well +5% would be good enough as that would get COBI above the 2224 (I found 2234 on the web, but can't argue with the math above), if the dealer can 5% that gets it to 2282.
Odd that Trek would not fix that before it left the factory. COBI also said my bike weighed 30lbs. but that i could change.
To many metric/imperial values getting muddied together. 1.12% is it.I appreciate that but expressed as a % would I be incorrect in calculating it would be only 1.12 % ?
How does your new Allant's gen 4 CX stack up against the gen 2 so far ?To many metric/imperial values getting muddied together. 1.12% is it.
Are you planning to try to de-limit it?How does your new Allant's gen 4 CX stack up against the gen 2 so far ?
Excellent !Are you planning to try to de-limit it?
