Hornblower
I bought Allant+ 7S Staggers for my wife and I about four weeks ago. In the four weeks I have put about 550 miles on mine (20 mile ride every morning except for Mondays).
Very happy with the bike so far. Quality of all the components and overall build is excellent. Getting about 65-70 miles per charge (primarily riding in ECO with an occasional bump up to TOUR or SPORT heading up steeper inclines.
I have added A Mircycle Bar-end Mirror to each bike as well as Bontrager Ion Pro RT Front Lights and Ion Flare RT rear lights. Bought some new pedals for mine (Bontrager Pro MTB pedal set) but haven't put those on yet.
In the four weeks I have had four flat tires on my bike and one on my wife's. Two of the flats sealed up on their own (bike shop put slime sealant in the tubes) but two of the flats (both rear tire) required me to pull the rear tire to replace the tube. The first time I pulled the rear tire off I was quickly able to break the tire bead and replace the tube but navigating getting the rear wheel back on was challenging. I finally ended up pulling the rear wheel center quick disconnect bolt (skewer) off the wheel to make it easier to get it seated back in the cutouts. The second time I could not get the bead to release on the rear tire and had to run to down to a nearby bike shop where the mechanic used a Park Tool PTS-1 Tire Seater to pop the bead off. He replaced the tube and getting the rear wheel back on the bike was a lot easier the second time. I will say though that if you think you can do a tube replacement or even apply a patch to a flat tire on the side of the road or bike path it may be challenging. I had mine up on a bike maintenance stand both times to get the rear wheel off and reinstalled. I have started buying some specific tools to be able to do some basic maintenance myself as well.
A couple of complaints:
1. As others have noted, not being able to turn the lights off from the controller. It appears this can be remedied with the software update or rewiring and will get the LBS to fix when I bring in for 90 day servicing
2. Occasionally get what I would describe as a rattling sound which sounds like its coming from the pedal area (or maybe the motor). Only happens intermittently when pedaling. Will get this checked out as well.
3. None of the Bontrager MIK bags fit on the Racktime Rack. After reading another post, did some research and ordered the correct adapter for fastening Bontrager bags to Racktime racks. People in the LBS were clueless about the whole situation.
Questions to others:
1. Battery charging - do you charge your battery to 100% each time? I was doing some research and found a couple of articles showing that charging to 100% gets you about 500 charge cycles but charging to ~80% gets you more like 1200-1500 charge cycles. You need to charge to 100% periodically to load balance the cells but that can be done every tenth time. Ineterested in what other owners are doing about battery charging. Since I live in the Phoenix AZ area I bring my battery inside after ride because my garage gets up yo 105+ F this time of year.
2. What other accessories/mods (if any) have you done to you Allant+ 7S? Any accessories you can recommend?
Happy riding to all!
