Yes I understand the BMS looks after things. There is so much info. on the web re. Li batteries it is mind boggling
I think it may have a balance feature - that's why they say to give it full charge the first three times.
If I were you I would drop a volt meaning stay in the 35v - 40v range.I have had my bike for 9 months now and have settled into a charging routine which seems to be working OK – but guess I won’t really know until the battery dies.
I ride the bike between 6 and 20 klms. a day. I recharge it every few days when it drops to around 36 volts+. I don’t allow it to get below 36 volts. I normally charge it to 41.5 – 41.6 volts. Am I doing the right thing? How often should I give it a balance charge and how to do this correctly? My charger is 2 amp output. I keep a record of all my charges on a WORD doc..
Thanks for the reply. I would not have thought that the lack of a "smart" battery charger or BMS would prevent the batterie's cells from balancing during a prolonged charge. (?) I'm being cautious here as a new battery costs A$800 + here in Oz.If I were you I would drop a volt meaning stay in the 35v - 40v range.
Unless your BMS supports balancing (which it probably does not) there is no benefit to the so called 100% balance charge.
The good news is with only a 2a charger and the modest discharge of riding of these hi energy cells, the battery (if quality and properly matched to begin with) should not fall out of balance.Thanks for the reply. I would not have thought that the lack of a "smart" battery charger or BMS would prevent the batterie's cells from balancing during a prolonged charge. (?) I'm being cautious here as a new battery costs A$800 + here in Oz.
According to the Lekker shop the bike has a Samsung battery pack. I guess there are Samsung batteries & Samsung batteries & then there are Chinese knock -offs. It is built with good quality components and I hope the same applies to the battery. Link to site -The good news is with only a 2a charger and the modest discharge of riding of these hi energy cells, the battery (if quality and properly matched to begin with) should not fall out of balance.
A smart charger doesn't come into play here as it does with hobby LiPo's.
A balancing BMS is how it's done and typically only found in high-end batteries. The jury is still out on whether or not the cost is justified.
Don’t stress about it and just enjoy riding.According to the Lekker shop the bike has a Samsung battery pack. I guess there are Samsung batteries & Samsung batteries & then there are Chinese knock -offs. It is built with good quality components and I hope the same applies to the battery. Link to site -
https://www.lekkerbikes.com.au/product/lekker-x-ebike/
I completely agree. I respect the 80/20 charge routine and those that use it. I actually used the 80/20Don’t stress about it and just enjoy riding.![]()
Bosch batteries are a completely different animal. Much more advanced battery management systems. Their high standards account for the pricing structure. Saw my Bosch buddy today. 17,000 miles on his first battery.I completely agree. I respect the 80/20 charge routine and those that use it. I actually used the 80/20
for while myself, but finally said. "I bought my bike to ride" and wasn't comfortable 'leaving' 40%
of my battery power unused.
Yes a brand name battery ( Bosch) in my case is expensive, but the joy I receive while riding my e-Bike
is worth the expense many times over. I'm not made of money, but when my battery is no longer
functional I'll buy another for many more happy hours and thousands of miles.
Don't get all worked up on the details...Enjoy the ride.
Stress? Satiate! Recently added a new one to the stable.Don’t stress about it and just enjoy riding.![]()
But always sold outI use a Luna digital charger and just select 80% and it does all the work. It also has selectable charge rates which is nice. I’ve seen folks use a digital volt meter to just shut charging down at a prescribed voltage if you want to baby sit charging? Luna charger is $100 and money well spent in my opinion considering our batteries are usually $500+.
My DIY hack can charge to any voltage with a 0.1V resolution without stress and at the cost of a pizzaStress? Satiate! Recently added a new one to the stable.
Tom is right... Bosch batteries are on a different scale and I believe that they do balance via the BMS.I completely agree. I respect the 80/20 charge routine and those that use it. I actually used the 80/20
I have been trying to find a Luna charger here in Australia with no success. What model do you have?But always sold out
The "damage" comes from heat in the cells and not the actual state of charge. A good BMS will taper down the current as it nears full. But do we trust all of them? Also how the gauge is calibrated. It's to the marketing advantage to push the limits as much as possible to make the batteries look good on paper. They have capacity specs but not lifetime.That pretty much flies in the face of every resource, everywhere unless you put some context in. How long was the 100% charge held, for instance? If you charge to 100% and immediately go for a ride, there's far less damage to the internal cell chemistry than there is if you charge to 100% overnight and let it sit from 2am until noon when you go for your ride. Or 3 days later. What was the charge amperage? 1 amp? 5 amps? Do you think that matters? What was the discharge? a steady 1 amp? 30 amps? Do you think that matters?
Isn’t Luna Mate still near you?I have been trying to find a Luna charger here in Australia with no success. What model do you have?
