Display Replacement Question
kmerenda
I have a Cannondale Adventure Neo Allroad (base model). The motor is a Bafang rear hub 250W G020.250.D 10, controller is a Bafang 36v CR S105.250.FC 3.0, and the display is a JYT S350 (JDGDS350YC). The display has a triangle CAN connection. I broke the display and want to replace it, but can't find anyone selling that model. Any tips on replacing the display with something similar, or tips on finding an exact replacement part?
Even if you found that display, software updates in the time since you bought the bike would probably make it incompatible with the old controller. Controllers and displays have to be bought at the same time, from the same source. Just finding the same connectors for the throttle, brake handles, PAS or torque sensor, that your old controller had is a real hassle. Watch the watts & amps on the new controller. Controllers that can supply 750 watts up can burn the winding of a 250 w motor. Controllers that supply only 250 or 500 watts will error and not run a 1000 w motor.
Often controllers bought from other than the OEM rotate backwards, and have to have the phase and hall effect pickup wires swapped. If you have round "watertight" connectors that has to be done out in the middle of the air, with unreliable splices of the wires.
That was a fear of mine. So, I should be looking for a replacement controller and display package that is compatible with my motor? anything else I should be looking out for?
