Guys
Tom
I am only relaying facts/information I found while doing this test,
and wondering "why" ONLY HERE in this first "G" method in the 11T selection,
there is such a drastic speed DIFFERENCE change?.
And this drastic difference DOES NOT show up anywhere else.
Gear = 11T = 11T =
---------G-----M-----
Eco 3=
31.1= 52.0= 20.9 mph Dif
Eco 4=
30.1= 53.3= 23.2 mph Dif
Eco 5=
31.2= 53.4= 22.2 mph Dif
Spt 1=
29.3= 54.7= 25.4 mph Dif
Spt 2=
30.0= 53.1= 23.1 mph Dif
Spt 3=
29.4= 54.7= 25.3 mph Dif
It is ODD to me, (on these drastic speed figures differences) is occurring only with these 6 settings/gearing.
"Or are these just readings on your display with the wheel off the ground?"
As posted in #34 post =
After the above tests, (and hanging from limb) I used the thumb throttle only.
"Or are you actually achieving these speeds? 50+ mph seems ridiculously fast unless the bike is geared super high."
I haven't road tested to find out this speed information, YET.
" Maybe the magnet on the rear wheel is misaligned and messing up your speed sensor, and causing other issues?"
From what little info, I have found on this item, (Magnet/rear wheel),
I don't think so, as it is there and attached as received and appears to be lined up correctly etc.
"Is your PAS capped but not throttle?"
This information is unknown to me, I only know my bike is unlocked.
GR
"Honesty Don... I don't know what it is that you are trying to achieve?"
I am NOT trying to achieve ANYTHING, I was reporting on facts/information that I found, and just wondering WHY, this happened only in this limited area/selection,
that's all.
I found this info very ODD as compared to the rest of the speed readings.
"If you do have overrun and you feel it is greater when riding, then film that as you said."
I plan on doing that, as I DO have overrun, I just need to figure out a SAFE way to film it, without me getting hurt or my bike damaged etc.
"The rest of this is a waste of time if you ask me and the time would be better spent actually riding and gaining experience with the motor and different settings in actual use"
I am sorry I wasted your time, and I Will be spending MORE TIME riding and gaining experience with the motor/different settings, when I can get get some decent weather, with the winds NOT blowing 15-20mph every day, and hopefully I don't end up walking 10+ miles back home because the bike let me down, as at this point in time I don't trust it
"as adding load things are going to be very different".
I don't understand what you mean by this statement?
"ymmv... especially with the bike hung from a tree
It would be better that the bike was hung from the tree,
instead of me...LOL
Al
"I'm inclined to agree. You continue to loose focus on the one issue you might have (over run) with all of this other data."
I am not loosing focus, I was VERY CURIOUS as to the WHY of the drastic speed readings I found and thought that maybe posting that information MIGHT provide some more information, as to why I have this OVERRUN problem etc.
As posted above, I will film/post this over run problem, I found when I find a safe way to do it.
I don't have the experience with this bike that all you others have.
Thank you all,
Don
