I have a Neo Extrem emotion bike and recently broke the lcd display (part No. LCD 20151123177). I managed to source a new one from a company in France (P/N: LCD 20210506142) - it was impossible to find spares in th UK. However when re-connected, the display shows error code 05 and warning
sign flashes when load is applied to the pedals. If the load is removed, the display reverts to normal. When the front brake is applied the same warning
sign flashes on and disappears when the brake is released. The controller model is BH-Neo-W3620A and serial No(?) is , 02 130617358. Rear motor No’s are 1306BH0158(E) & M155RD3612. The bike worked fine with the old display before brakeage. With error code 05, the motor does not run and I have read what I can find online: for this model error 05 seems to suggest a brake interface issue which given the brake lever sets off a warning seems a reasonable assumption. I've troubleshooted as in the notes, eg. check brake levers, check connections (all ok), motor sensor (not checked but considered unlikely as worked before), and am tending towards a firmware issue between the display and the controller, perhaps UK spec vs Euro spec? I hope someone can throw some light on what may be the cause. I have also contacted BH Spain direct - useless!
![Warning :warning: ⚠️](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/26a0.png)
