Raymond Potvin
Hi everybody,
I've had a BBS02 500W 48v for about eight years, and the display stopped working properly after a year. It would open and let me put in the assist force I needed, and it would close right after while indicating an error, but the motor would continue. Nothing but the engine worked. It started when I pedaled and stopped when I didn't. I had to close the display and reopen it to change the assist force. It was OK for me, so I didn't try to fix it, until recently the display stopped working and the engine stopped starting. I opened the display to find that the battery was leaking, so I changed it but that didn't help, so I ordered a new display, and it works but I still have to program it for the motor to start. The problem is that, seven years ago, I removed everything that didn't work, and I'm not sure I kept everything. What I would like is to be able to program the engine as it was, without the speedometer and wheel diameter and electronic brakes and the throttle etc... I don't need them, I just need that the motor starts when I'm pedaling and the assist force adjustment.
Anybody can help me out?
Thanks a lot!
Raymond
Thanks a lot!
Raymond
