enforcersu
I never really have an issue changing a flat on a ride on my normal bikes, or even my mid drive Creo. My issue is that the Stromer with the hub motor is a different beast.
I've seen some folks try to patch the tube while still on the bike, but do you folks generally remove the rear wheel and swap tube out on the road? Patch while on the bike? something else?
I'm awaiting my ST3, but prior to 2020 I would commute quite a bit on ST1X. I just recall the rear removal process to be quite an ordeal, and that's the one thing that has me concerned about using this for commutes, given I generally will get a flat every couple of weeks due to the staples, nails and other debris on the side of the road i can pick up.
