I did a bike "fit" and paid handsomely for it a year ago on 2 bikes.Two words: bike fit.
I'd suggest asking around at a sports medicine or physical therapy place to get a referral for a good bike fit. A competent bike fit consultation will likely cost much less than all of those saddles you have tried.
That brings up another point. It might not be you, the saddle, or your choice of clothing. It might be that the bike you are riding just doesn't work for your body proportions. That might be the wrong size or it might just be the wrong bike.
No padded shorts or saddle changes are going to "fix" a bike that is improperly adjusted for you or is just the wrong size.
Also: take multiple photos of the saddle position after you've got it dialed in from a proper bike fit. Then you can start experimenting with different saddles or padded shorts. You might need to make tiny (likely very tiny) adjustments from that original position but you should always start from the properly fitted position when you make adjustments.
Guru has one.Perhaps a seat post shock
Here’s hoping that the Ergon saddle works for you. By sheer coincidence, I ride with the same on my fat bike and it’s fine but then again, I don’t spend hours on it at a time.I did a bike "fit" and paid handsomely for it a year ago on 2 bikes.
I have chamois padded under garment(s).
I tried the Ergon saddle Stefan suggested today, OK for 10 miles, we'll see as it goes forward.
Thanks for you insight.Here’s hoping that the Ergon saddle works for you. By sheer coincidence, I ride with the same on my fat bike and it’s fine but then again, I don’t spend hours on it at a time.
You’ve already spent a fair amount of coin on a number of different saddles and still can’t find the Unicorn that eludes you. I’m not sure if all the additional advice that’s being provided to you with respect to Brand X,Y or Z is going to help you in the long run since every rider’s experience and body type is going to be diverse just like suits or t-shirts which come in varying sizes. One can’t help but to think it might have more to do than just the contact point that you’re sitting on as others have pointed out. By proper bike fit, can you elaborate? My better half also found herself in a similar situation and finally made an appt for a fitting with a physio/kinesiology team through a LBS. She also went through the same physical assessment that was shown in the video that @Mr. Coffee posted. The shop used the Retul system and trained techs to capture and analyze her motion on different planes via LEDs attached to specific body points as well as digital sit bone and footbed devices. Retul is not just exclusive to pro cyclists but for riders of all ages and experience levels who are in need of improving their comfort or performance on their bikes. In the end, they did replace the stock saddle with one that was more conducive to her anatomy as well as a shorter stem, trimmed the seat post, adjusted the handlebar angle as well as shorten the throw on her brake levers. Her data is kept on file and a digital map of her bike was created so that she can return if further tweaks are required. She now rides with very little to no discomfort at all. She does ride clipless but I’m sure the techs would have accommodated flat pedals as well.
A lot of people, in fact nearly everyone, on this forum rides with flats. Which brings up something interesting and important: most of us have the wrong foot position on a flat pedal, and that can mess up comfort and fit. So at least what I do now is if I start feeling some discomfort I check my foot position and get it back in place. You might also need to consider proper (or at least different) insoles on the shoes you ride with flats.... She does ride clipless but I’m sure the techs would have accommodated flat pedals as well.
Out of curiosity, did you make those changes before or after your bike fit?However, the purpose of my initial modification(s) to change the handlebars to a more swept back position was that I suffered tremendously with wrist pain and shoulder pain (with OEM handlebars + stem). I additionally raised the stem with the Kinekt Suspension Stem 100mm 30° rise and a Kinekt XR Seatpost. All of those mods made my riding much more comfortable,
Changes were done prior to fitting. So may the "fitter" was not 'fit'?Out of curiosity, did you make those changes before or after your bike fit?
Also, take a look at https://www.myvelofit.com/ and see if they can help. I think they start off with a free tier and it might give you some stuff to try.
