What’s your real-world e-bike range?
michaelbrown12319
Hi guys! I was thinking about how subjective the “up to X miles” is, so I wonder if you would like to share your actual consumption and the conditions behind it, for example, motor type, voltage, your weight or cargo, terrain, temperature... I'm curious to know if there is a significant difference between what you experience in different situations vs the range that manufacturers advertise
E-bike manufacturers market battery the range of their e-bikes for ideal riding conditions, a young sporty rider requiring minimal assistance, and possibly on the flat. The brutal truth is "the more power you can add to your ride yourself the farther you can get". The unassisted range is infinity.
Here are several factors affecting the battery range:
  • The battery capacity
  • The e-bike motor assistance
  • The leg power rider's contribution into the ride
  • Elevation gain
  • Wind assistance or resistance
  • Terrain ridden
  • The cruising speed
  • The system weight (rider + e-bike + cargo)
  • The tyres used and the inflation pressure (rolling resistance)
  • Continuous ride or frequent starts/stops
  • Ambient temperature
  • Anything else?
Any discussion of "real world range" is pointless. Enough to say, I can ride the same e-bike with the same battery for 60 or 25 miles, given all the conditions. The real range just needs a couple thousand miles ridden in different areas and all year long to gain a personal experience for a given e-bike.
I could throw my numbers at you, but as you've already suggested, there are many variables – many more than you have already listed.
At least with electric cars of different makes, there is a common reference point of "miles per kWh" or kWh/100 km, but in that case nobody is pedaling to contribute.
With bikes, Eco vs. Turbo mode, thumb throttles vs. pedal assist, hub vs. mid drive, and the popularity of utterly inefficient tire choices... you get the picture.
My commute bike can swing from 50 one ride to barely 20 the next.
I had an 840 wh battery on my bodaboda cargo bike. There are 77 hills on my 30 mile usual commute one way, and if I started with a full battery and pedaled all the flat and low grade portions without power, the controller would red light and cut out on a 12% hill 2 miles from my destination. The commute is 30 miles off the flatter state roads, and there are numerous 8 to 12% hills. There is a 200' rise overall. Days when there was a 30 mph headwind all they way home, the battery would cut out further from my destination.
That was stolen, good riddance because geared hub motors that would climb a 12% grade have been outlawed. I had a 1300 w ebikelingone that wore out the gears at 4500 miles, and a Cutler Mac 1000 w one that wore out the one way clutch in 5000 miles. Last 750 w hub motor burned out in 2024, to make a matched set of 3 burned 750 w legal motors. 8/31/26 I bought a PakYak with a mid-drive that is supposed to cool better than a geared hub motor. It had better, because in the year & 4 months I have been off the bike, I cannot climb 1% grades with the power off. New battery has 2/3 the watthours of the old one. I've had the bike since 9/18 and got 6, 12, & 8 mile trips in before a spoke nipple broke. USPS has had the box with the part for 6 days, 3 of them in town, and did not deliver today either. I don't think I will dare ride the commute to my summer camp until I buy another battery. Has to be Momentum, the battery reads 1 v if it has not communicated with the computer in the controller.
...a young sporty rider requiring minimal assistance...
I was thinking about this on my ride in to work just now...
My commute is a hair over 11 miles and mostly flat, just 200' of gain on the home leg, and yet in Eco mode I'm pushing my luck to complete two round trips (45 miles).
But if I take this same bike out and casually ride the Oakland-SF-Golden Gate Bridge / Marin Headlands loop into Larkspur with my son, we can rack up 50 miles with much more elevation gain, and still have electrons left in the tank upon reaching home. And I assume this is because the Shimano (and Bosch) mid-drive system on these bikes respond to how much effort is put in to the cranks, and tries to match it.
So if I push it harder on my commute, even though I'm in Eco, I'm probably expending way more Watts per mile than if I'm casually kicking it with the kiddo.
I'm not sure that that is true on hub drive bikes or throttle controlled, or even Bafang mid-drives -- would greater rider input act to relieve power requirements from those motors?
I find it interesting that my Motobecane Ultra eAdventure, which weighs 46-47 pounds with a 418Wh battery and has a Shimano E5000 Class 1 motor, gets about the same range, and with the same elevation, as my 36-pound Canyon Grizl ON: CF 7 with the Bosch SX Class III motor.
Both are will probably do a bit more than 40 miles with a bit more than 4,000 feet of vertical, which is typical for riding conditions here... every 10 miles involves roughly 800 to 1,000 feet of vertical for most rides.
The difference is, of course, that the Canyon is much faster. It's not unusual for me to do a couple of blocks just under or over 30 MPH, while on the Moto, I would probably just kiss 28 MPH and cruise at around 20-25. The Motobecane climbs steep hills at 5.5 MPH, while the Canyon climbs at more like 7 or 8 MPH. It doesn't sound like a big difference, but running errands is much faster on the Canyon, and my 4.1 mile local fitness loop-- through steep hills and sharp hairpin curves-- is tricky on the Moto, but harrowing on the Canyon-- those few extra MPH mean I REALLY have to pay attention.
I think the Canyon's "Eco" range may be a bit better, but there's no place to test it here. But I bet either bike could do 60 to 80 miles on flatter terrain with gentle, rolling hills.
And the Canyon starts getting skittish at 38 MPH, while the Moto doesn't get jumpy until 43 MPH.
Riding the Canyon did change the way I ride the Moto-- I'm now keenly aware that higher cadence with the Shimano power plant delivers more power, and consumes more juice. Previously, I kinda knew that, but it didn't figure into my riding style much.
So it absolutely depends on use case scenario.
Nate, the batteries also degrade with time and the number of charging cycles... I've noticed it already as all my e-bike batteries are old!
Strangely, the Moto's range has not decreased noticeably since 2021. I think that is because it only has 3000 miles on it, but also because the motor is underpowered, e.g., does not draw down the battery as fast, which decreases its lifespan. I expect to see faster battery degradation from the Canyon.
Nate,
The first thought is that for the same e-bike ridden under identical conditions and at the same speed, everything is down to the total energy used for the ride, which can be split into the rider's and motor's contribution. In them olden good days, there was an app for Specialized e-bikes (BLEvo) that not only could extract any possible information from the e-bike but also made very detailed analyses of the rider and the e-bike interaction. One of the most interesting parameters was "Rider's contribution %". My powerful big Vado did 67-75% of the work for me on long rides while I was providing 55% with my legs on a half as powerful Vado SL (so the e-bike contribution was 45%) on similar routes.
On the other hand, setting the assistance in either e-bike the way each of them provided the same actual assist (motor/leg power multiplier) and peak power resulted in a very similar battery consumption and average speed, provided the rides were on the flat.
Those times are gone but I simply can see (by currently available parameters) my leg power is decidedly lower for the powerful e-bike compared to the weaker one if I maintain the same average speed. So I just need to pedal harder on the low-power e-bike to achieve the same.
Let us not discuss the throttle-only as it is irrelevant: it results in the worst battery range. Now, the motor efficiency. A mid-drive motor is very efficient if the rider can maintain the cadence above 70 rpm (ideally, above 80 rpm). Regarding a hub-drive motor, it provides a constant assistance per the assist level. Additionally, the rider of the hub-drive motor e-bike gets into the equilibrium with the motor, so it results in a constant speed for a given assist level. Hub-drives can be efficient and fast as long as the rides are on the flat (a good commuter bike). However, the hub-drive motor efficiency falls off the cliff if the hills come into the equation. (In my opinion, the rider's effort on a hub-drive is constant per the assist level, and it does not affect the battery range).
Now, very powerful motors such as Bafang or Avinox mid-drives. If the rider opts for high assistance, the leg movements are just a signal to ride -- your legs act as a throttle -- but the motor is doing almost all the work (ghost pedalling). Certainly, that affects the battery consumption a lot. That's why such powerful e-bikes have monster batteries that make the e-bike a heavy tank...
I do not have a known 'real range' on my Riese and Müller Supercharger, which has a 1,250-watt battery capacity, but I work on a safety margin of 150 kilometres when planning bikepacking rides.
I think that's a mistake on this forum. I don't own any throttle-controlled bikes but I've come to the conclusion that we "pedal assist purist" types are in the minority.
The Original Poster who posed this question could very easily be in the throttle camp!
And actually, that could give some interesting data points, too. A throttle only rider pegged at 20 MPH all day, every day is going to have very different results compared to 15 MPH or 28 MPH. Hub vs. mid-drive would have the same relevancy as pedal assist, especially once hills are introduced.
The throttle can just flexibly set the assist level for a hub-drive but the rider is still pedalling (the throttle is used to set the cruising speed only). With throttle-only, the contribution of the rider is 0%, resulting in the shortest range possible. We could as well discuss e-scooters :)
15ah battery, 2500w peak controller, riding flat ground, throttle, letting the bike do 90% of the work, average 20mph.
Best Ive ever got is 30 miles.
Legal bike UK, 15mph limit, 500wh battery, 550w peak ,pedal assist only motor, flat ground.
Best is 45 miles
15ah battery, 2500w peak controller, riding a very steep mountain off road trail, throttle, letting the bike do 90% of the work.
5 miles.
10 miles including poor mans regen.
FWIW, the advertised range for my bike with 500W rear hub motor and 17.5AH battery on smooth level ground for a 150# rider using minimum PAS is 65 miles. These specs assume you charge the battery to 100% and discharge until the BMS low voltage cutoff trips, usually around 15% in my case. Many here observe the 80-20 rule to maximize battery life, but doing so has a significant affect on range.
I'm heavier, carry a significant amount of gear and under similar riding conditions, get around 50 miles per charge. Most of my rides exceed that, so I carry a range extender battery. As already stated, there are many variables that affect range, so individual results may vary significantly from manufacturer advertised specs.
A few things I do to maximize range are:
Use maximum allowable tire pressure.
Keep the battery warm for rides in cold weather and top off just before a ride.
Carry only enough gear (weight) required for a particular ride.
Use cruise control, if available, to minimize wasteful current spikes caused by irregular pedaling.
Turn off the battery when stopping for more than a few minutes. Many bikes have a parasitic drain caused by electronics, lights, USB devices, etc.
When trail riding, listen to your tires. Choose the smoothest track where the tires make the least noise. This reduces friction.
Don't wear loose fitting clothing, which can increase wind resistance.
Individually, these tips don't amount to much, but taken together, a significant range improvement can result.
That is bigger than most people think about. On a torque sensor bike high speed pedaling that is super smooth all the way around will get the best range. Wind resistance increases exponentially with speed. So, keeping it down around 20 Kph is best for range. The surface also make a big difference. New tarmac is best. Counter intuitively, lower tire pressures can also give the best range.
PSI Recommendations for a 150-Lb Rider (700c x 1.95 / ~50mm)
Setup TypeRiding SurfaceFront Tire PSIRear Tire PSI
TubelessSmooth Pavement / Commuting35 – 38 PSI38 – 42 PSI
TubelessMixed / Hard-Packed Gravel30 – 33 PSI33 – 36 PSI
With Tubes (Clinchers)Smooth Pavement / Commuting40 – 43 PSI44 – 48 PSI
With Tubes (Clinchers)Mixed / Rough Road35 – 38 PSI38 – 42 PSI
this is very interesting to know and apply, I will try to keep those 20 Kph, I don’t usually keep track of these variables
Getting really good range is more of an approach and philosophy. Someone who rides a bike like a person sailing a sailboat will do much better than someone riding a bike like someone who does it like its a cabin cruiser. I am constantly shifting, such as down shifting when starting to approach a corner. Also, conservation of momentum plays a huge role.
Science does not say that. If what you say were true, the competing cyclists (who count every watt) would still run their tires at 100 psi but they do not anymore. To achieve the least rolling resistance + impedance, you need to set your tyre pressure according to one of these calculators:
Rene Herse (simple)
Wolf Tooth (detailed)
A good educational material. (Click to watch on YT).
In the Pacific theater of WWII volunteer Charles Lindbergh was able to increase the operational radius of P-38 planes by 50%. It is not just the plane (or bike,) it is more about the pilot, (or rider.) He made some resets, trimmed the tabs, and went for efficiency. Then he showed others to do the same. Officially he was not allowed to fly in combat, but he did 178 hours of combat missions in the Pacific and flew in 50 missions for the Army and Marines. Many Americans don't really know how to shift or how to pedal. With cars, they only have driven automatics. They will tend to keep the bike in the highest gear and stomp on the pedals, down left and right, not spinning. When they stop, they will launch by using the throttle. The smallest cog gets shark fin shaped teeth and the chain is badly worn to the point it is skipping and the chainring needs to be replaced.
Rene Herse (simple)
I don't disagree. I was only relaying my experience. I'm not saying max tire pressure is most efficient everywhere under all conditions. I've done a lot of testing by recording range vs tire pressure and max works best for me for where and how I ride. YMMV.
As Bram Hoekstra noted: "Soft tyres means the energy is lost in the tyre casing (rolling resistance), firm ones means losing energy in your body (impedance). There's a sweet point between these two". With firm tyres, you only have an impression you are riding fast.
Some of the points you mentioned assure a real range gain (tight clothing, avoiding excessive weight, switching the motor off for longer stops...) and other give marginal gains (added together they will give several miles more). The major factors affecting the range in the warm season are:
  1. The system weight, especially when riding the hills. The rider has no influence on own body weight (which is the biggest factor) then the e-bike weight matters. For instance, an e-bike with a huge battery uses part of the battery energy to carry its high weight.
  2. Elevation gain. Riding the hills is draining the battery the most. Coasting on the descents with only necessary braking extends the range
  3. Wind. Headwind sucks on the battery, tailwind gives great gains
  4. Cruising speed. High speed is swallowing the battery (air drag)
  5. Terrain. Smooth asphalt eats the least, dirt kills the range.
There are way more parameters (even the tyres used do matter), but the five above are not marginal; they are fundamental.
