Hello from AZ
Go-Rilla
Very new to the ebike scene, but I've been a bicycle nut since I could first pedal. I recently decided that I want to commute to work 2-3 days a week, but, as the trip is 16 miles one way, I made the foray into ebikes. I bought an Aipas M2 Max, which, like all other bikes, I've begin modifying to suit me. It's a tank, to be sure, but it flat out boogies when I need it and, in PA3 or 4, makes the commute easy without breaking any laws.
Cheers all!
@Go-Rilla, Welcome. I modified one. I installed four piston hydraulic brakes, better grips, Schwalbe PickUp tires, and a push-in throttle. The push-in throttle requires a throttle modification. Above the connector swap the red and white wires. It is far safer and more comfortable than a twist throttle or a thumb down throttle. It also got a Bontrager Boulevard saddle.
I'm running a thumb throttle, but I hardly ever use it. Four pot front brakes are on the menu, though the current 2 piston hydraulics do a pretty good job already. I have a Brooks Cambium C67 on it currently and swapped out pedals (for Look Geo Trails). I have a set of less chunky Arisun tires that will be going on soon along with Tannus Armour.
The Apias I worked on went out yesterday. I could not use the pre-bleed rear hose. It had to go through frame and was extra-long. For some reason that is inexplicable, the bleed was a huge pain. Everything on that bike is cast iron, frame cranks...a magnet sticks to every part of the bike including the rims. The PickUp tires were a huge improvement. The original tires would get flats two times a week in this thorn season.
What brand of 4 pot brakes did you use?
One guy wanted a quote on four piston hydraulics. I said go to the bike shop downtown and get a quote from them and then I will immediately meet with you and we will sit down to discuss your options. He was quoted $450 for the job plus some tax on the parts.
We got Zoom brakes from Amazonia; at $90 plus tax for the pair. Okay, what if they only stop 5% less better than brand X? They will still stop 85% better than what you have.
Pro Tip: Remove the existing cable housing, keeping the braided cable in place from the rear caliper. You will use that with a build up on the cable with 1/4 inch marine grade adhesive shrink tube 4:1 to attach it by running it a bit inside the new hose. That is now the guide to pull the new hose through the frame. See Park Tools videos on how to bleed brakes. A bleed kit is maybe $25 from the Amazon basin. I used new sintered bronze pads. Keep any oil away from the bike and pads and down low for gravity to work its magic to remove the air. Never over tighten a brass olive.
Another question: Has anyone here replaced the crank arms on their M2 with ones made of better material? If so, recommendations?
I was going to do that. They are cast iron. The problem is that the right one is fused to the chainring, so you need an entire crankset. If you don't want to install a new chain you need to count the number of teeth on the chainring and get one the same size. I recall it is something like 38-t, but check to be sure. A larger one is faster, a smaller gives easier climbing.
