spokewrench
- USA
I read here that an emergency generator can lose its magnetism. I googled. One source said time will demagnetize, but it takes decades. You can do it quickly with an AC field, heat, or hammering.
When it comes to generators, one source said you must run an emergency generator every two weeks to maintain magnetism. Another said 15 minutes once a month. Another said running without a load, or shutting down with a load, will demagnetize a generator. That last one might make sense. If the engine slows while current flows, maybe you lose the phase relationship and it will be like demagnetizing with an AC field.
Another source mentioned three methods. Stroking the rotor with a magnet could do the trick. (I'd have to get to the rotor.) Current from a battery can get it going. (That sounds like flirting with disaster.) The third method is to plug in an AC drill and, with the dead generator running, spin the drill backwards. One youtuber said it had worked for him on two generators. A long list of commenters thanked him and verified that it had worked. It sounds dangerous, but it seems that if it works, it takes time for the generator to produce enough power to spin the drill fast.
Maybe rotors aren't made of the kind of iron that holds magnetism long, and maybe they're laminated. I wonder if heat accelerates the demagnetization. If I wanted to switch off a generator that had been pulling a big load, maybe I should let it idle a minute after switching off the load.
Any advice?
Any advice?
