After playing drop-the-wedge-in-the-seat-tube
I have pushed some pieces of sponge into the sear tube. If I forget about the wedge, it won't drop down into the motor chamber.
my workaround is to drop the bike on its side (on an old blanket to prevent scratching) whenever adjusting saddle height or changing saddles.
I invert the bike, let the wedge drop on the floor and put the bike on the wheels again :)
The Kickstand Blues
Just recently, an unpleasant incident has happened (don't ask). As the outcome, the Vado SL (Gen 1) kickstand got broken. First I thought removing the kickstand would make my Fearless even more lightweight (the kickstand is heavy!) But no, I cannot live without the kickstand. The issue is I couldn't find the exact replacement! I should have measured the length of the kickstand before I threw both halves away...
I've ordered a 332 mm Specialized Turbo kickstand, similar to the one used on my big Vado. What I don't know is whether the bolt spacing in the new kickstand would be 40 mm, and also if the length would be proper (the original was adjustable).
Perhaps you know the part number of the original adjustable, 40 mm Vado SL kickstand? As I can see, the Specialized Turbo 332 mm MY 2017 kickstand is bolted from the inside, while the original was fastened from the outside (still keep the original 25 mm long bolts).
Re: Kickstand
I bought this one. It is OK but a bit long... Such long you even cannot adjust it, just bolt it on and use.
This one would be better. It would ensure a better tilt to the side.
In case anyone of you needs a replacement kickstand for a Vado SL Gen 1 :)
Re: Kickstand
Bought a bog standard Halfords one in '23. Cheap, length adjustable and solid, seems fine after over 2 years of use:
Just out of interest, Ras -- in your own time -- could you please measure your current distance from the mount down to the floor along the kickstand and tell me?
Sure- but it's adjustable. I just press that red button halfway along the stand and can lengthen or shorten.
