I have those shifters on my Disc Trucker. I bought them a long time ago though, so I don't remember where I got them. There was also an I-Spec adapter for them for the brake handles IIRC. I have the TRP Quadiem G-Spec brakes on the bike. I am on my work computer at the moment. I can check on my personal laptop later.Plus I can use any size tire. Trying to find something used is tricky unless your getting all your parts after. found a double crank in the right size I was not sure if I could most dont go down that low.
I dont need a triple. 20.00 less than normal. https://www.ebay.com/itm/306575703942 now I need to find the front shifter for this setup. https://www.ebay.com/itm/164445556176?var=464058594819
what front derailer are you using? this guy has the right clamp but it does not say bottom pull. https://bike.shimano.com/products/components/pdp.P-FD-M8100-M.htmlI found it. Mine are the XTR SL-9000 shifters. I bought them as a pair from Universal Cycles in Portland in the spring of 2019 for $89. Now they want more than that just for one shifter.
https://www.ebay.com/itm/177739916383?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item
That link doesn't work for me. I am using a Shimano 105 FD-5700 on the front. It has a 16T capacity and I have a 50-34T double crankset. I have a Shimano XTR RD-M9000 SGS in the back.what front derailer are you using? this guy has the right clamp but it does not say bottom pull. https://bike.shimano.com/products/components/pdp.P-FD-M8100-M.html
no but it works with mine. they actually match. but will it work on the bike? thats what Iam not sure of it has the right clamp but is the cable orientation right?I just looked up the M8100 and it only has a 10T capacity, so that wouldn't work with my crankset.
but my cranks match it so it may be smoother. Deore FC-M4100-B2 Crankset - 170mm 10-Speed 36/26t 51.8mmYou could probably make it work, but it wouldn't fit the cable routing on the frame. I would get a road derailleur with a bottom pull. Mine is working with my XTR shifters.
ya but that cost would be about the same as having it done and its not something I would do again. I did make a tool once to put the star nut in. I will have it cut with all the spacers since I won't know what I need till I hop on. crap I thought my front dt swiss up could convert from qr to 12mm through, but it does not do that. it looks like it has to be bought with through or qr. I have my spare tandem wheel, but it wont go tubeless.Well, just get the cable housing clamps and run the cable housing on the top of the downtube to the front derailleur. You can make the M8100 work. You don't have to use the braze-on cable guides. I cut the steerer tube myself with an inexpensive pipe cutter. It's good to wait to cut it until you know how high you want to mount the stem.
I think this is the headset press I have. Half the price of the Park tool, but works fine and I don't need it too often. https://www.jensonusa.com/foundatio...MI_7Or7KiekgMVES9ECB2QdRMAEAQYASABEgKUavD_BwE
That battery dying at 48% is brutal—no wonder you're hesitant to buy another one. 20k miles is a massive achievement though. Do you feel like the motor is starting to sound rough, or is it just the high mileage making you nervous? Either way, that 42t chainring is definitely your enemy on those Portland blocks. A light analog bike with a proper 1x setup would probably feel like a rocket compared to what you're pedaling now.all the hills are short one block. portland isn ot flat anywhere. I can have a 3% grade on one block and two blocks over its flat. I have a allant 8 with a Gen 4 motor. The bike has 20k on it. Yes its hard to know how long the battery will go. my first 500 battery died after about 520 cycles. it was letting us go 15 to 20 miles on our tandem when it died in the middle of the ride with 48% left so you never know. the bike is a dog with 42t chainring and 11-34 cassette. the 2" tires or soemthing makes it so sluggish compared to my first bosch powered bike. with all the rain and my miles, I am worried a new battery may outlast the motor.
no the motor feels good but with all the rain I ride in can cause issues. Best case I will have a backup bike and a new battery. but it may be time to just have a e tandem and the trek for casual use.That battery dying at 48% is brutal—no wonder you're hesitant to buy another one. 20k miles is a massive achievement though. Do you feel like the motor is starting to sound rough, or is it just the high mileage making you nervous? Either way, that 42t chainring is definitely your enemy on those Portland blocks. A light analog bike with a proper 1x setup would probably feel like a rocket compared to what you're pedaling now.
no thats my doner bike. thats where all the parts are coming from. well all that work but almost all of them do. the front wheel wont. I thought I could change the endcaps on the dt swiss hub but nope. took the performance speed moto out of it and put it in the tandem after it had issues. we have gotten that sucker to 27 its a crazy ride. I wanted to try the bulls with a tubeless setup see if it was a less harsh ride but never wanted to go to the effort.Did you get rid of the old Bulls?
