Anybody tried Clik tire valves?
I just floor this guy as the little tool was such a pain. I may cut it short
Welp... we're pretty much into October now, and that makes 5 months into Clik valve usage, and many kms of riding/experience.
Not gonna lie, I wish these things were available years ago.
The weekly loss of air is way down, minimal at most. I think I'm down to needing air maybe 3 to 4 weeks instead of weekly/two weeks.
That and the ease of filling and not needing to undo that stupid effing collar is bliss!
Presta had a good 100 year run, and I'm done. YMMV :)
Five months into my Cliks as well. Post-Presta life is good. Don't miss 'em a bit.
Have to air up my tubeless tires more often than you do, but the rate's no different than it was pre-Clik. It's so easy now, who cares?
Anyone else carrying a Shrader adapter for emergency air — e.g. from another rider or gas station? Not that I've ever needed that.
Yes, I can imagine your tire pressure level being higher than mine at 30psi. If you're tubeless I would think that the culprit more than valve related?
But... the convenience... the ease of adding air... the lack of need for me to find a tool to open the valve...
No regrets, no way back. :cool:
I run 35-40 psi front and rear. Pretty sure my background air loss is mainly at the rim seals.
been pretty happy with them too. I had one time where the valve would not close and let the air out but it did not repeat. the tires fill faster too and my oressure gauge is always right on with presta sometimes it took a bit or it would not read rigt till you started pumping. if you need ot let the air out use one of the adaptors without the hose works great.
Great to hear.
We've been so conditioned/exposed to the norm that this change seems a tad radical, but to me it's about time...
My Clik days are over. I gave them an honest try for five months or so but they are not what I hoped for. Both valves are partially plugged and the pump head to valve seal leaks a little unless it’s held motionless while snapped on. I use Orange Seal and usually rotate the wheels so the valves are at 6:00 to drain between rides. I do forget that occasionally but still, both are partially clogged and they can’t really be cleaned. The Clik mechanism doesn’t let you clean out the inner portion very thoroughly.
So I just put in muc off big bore lite valves to try out. They don’t have any core or spring loaded mechanism of any kind, just a ball valve that you twist open and closed with a quarter turn. They worked great in mounting my tires and injecting sealant in. They’re basically like a presta valve without the valve core, so lots of air flows in and you close the ball valve before removing the pump head so there’s no air loss. Sealant squirts right in and it’s easy to check the level with a dipstick - no core to remove, just give the valve a twist.
Time will tell if it’s the answer I’m looking for but so far it is looking good.
Interesting, and unfortunate but cheers for the feedback!
So far, Clik has been flawless for me. I use regular Stan's sealant without ever thinking about the position the valve is at when parked.
Bummer, but as stated earlier, there is no single thing that satisfies all comers.
Here's hoping your new choice works well for you!
you need to get some plumber's silicone grease and grease the valve up before installing it. that has worked well.
The plugged area is inside the Clik valve - the spring loaded plunger can only be pulled out a mm or so and I can’t clean out the tiny bits of gummy sealant inside the shaft. If I were able to put grease in there it would only make things worse. It is the airflow pathway through the valve. I did try spraying some light lube in but it wouldn’t last long anyway.
Fingers crossed for the muc off big bore valves!
well yes you would need a new valve. but I do this on all my valves and it works well. fresh valve grease it up. I have had so many clogged valves, sometimes only getting one or two fills of air. this has worked really well.
I wonder if they will get fouled by sealants like Stans, Slime, Flat out, etc. ?
Maybe. I use Stan's in my tubeless tires. Switched to Clik valves almost a year and 3,000 mi ~8 months and ~2,000 mi ago.
Flawless except for 2 top-offs in a row that made me wonder about sealant in the front valve. Used the reservoir on my Topeak Joe Blow pump to blast any plugs back into the tire. Two blasts in quick succession restored normal inflow.
Flawless ever since. Still really likin' my Cliks.
