Magic (not real magic) chain lube for outstanding lasting performance and virtually no wear
I'm not starting with a perfectly clean chain every time I lube. If I did, I'd probably only use wax.
Not before every lube... Just a new chain to remove the factory coating.
By not doing so I found the chain stayed messy until it was eventually eliminated by routine chain maintenance.
Lol, I think I will pass on that one. I would like to find one decent but not too expensive product that will help maintain my chain.
Most any work just fine and the difference between the popular brands is negligible. Some last a little longer between intervals than others but conditions play a bigger role in my opinion.
If it were me now, I'd skip the whole hot wax business and just clean my chain really good and use the T-9 that you're using.
The ZeroFrictionCycling testing guy says otherwise - that the worst brands, even popular ones, only last 1/10 the distance of the best chain lubes.
Quote here (timed to start):
you dont even peddle you should just spray paint your chain.
Actually KMC already painted the chain,..
I think it's just a stupid gimmick.
It was "coated" with something fancy for no good reason other than a cosmetic one.
Fricken stupid.
It just wears off and serves no purpose.
As for me waxing my chain, you're right, I never pedal, but I've had my wheels and chains off my e-bikes more than a dozen times, and having a crud free chain just makes sense to me.
I ride on dusty gravel roads, and if I used an oil based chain lube, my entire chain drive would be a mess, with gritty dust sticking to the oil and grinding into the chain.
My 7th gear is caked in dust in this picture, but if I just put it in 7th gear and spin the chain, the dust just falls off.
Most lube seems to give me the same amount of miles, and when you put 200 miles a week on my bikes, you get a lot of time to observe. and after over 40k on e-bikes and a lot of chains so I go for ease of use less mess and how long it lasts in the rain. rock and roll blue is great when you dont have a lot of rain. its fast to apply easy to wipe off does not make a big mess. I get maybe 40 miles when I ride in the rain.
SilcaSynerg-E E-Bike Lube lasts a really long time, over a month with rain rides, so maybe 500 miles, and without rain for a few months. It does not make a huge mess either. But it's a hassle to apply as it's so thick.​
But yeah, I see no reason to not keep using the T9
In the ZFC tests, which being real data isn't something you're probably interested in reading, T-9 came in 33rd at the end of the 1,000 km dry/clean run, 38th after the dry/dusty run, 36th after the 3rd clean run, etc. Pretty middle of the road. There are worse, sure, but there are also better.
In general, the immersive wax and then drip wax lubes fare the best, even in on-road dry and clean environments. Kind of an eye-opener to me.
That's what I'm going to do.
I've already done the immersive wax, but I'm going to wait till I've got about 20 miles on the chain before I use the drip wax.
I should be ready for the drip wax by the end of next year. 😁
I thought about wax, but the hassle of taking the chain off and off again, and all the rain and cold, I think it would turn into a hassle. Roadies don't ride in the winter rain.
I just give my chain an annual cleaning and hot wax treatment.
I'm sure that would work (for someone that actually pedals) along with some sort of liquid wax lube applied the same way as an oil based lube and applied regularly.
If only waxes are used, you shouldn't get a messy chain.
If a waxed chain lasts as long (or almost as long) as an oiled chain then I think having a clean chain is worth it.
I might just do it as a winter project. But yeah, I see no reason to not keep using the T9
Next new chain I'm going clean from the start just as prescribed by Dr. @PCeBiker! Not that I think it'll make it last longer... but I do want to be closer to god.
I decided to bring myself closer to God.
It only cost me twenty two bucks to buy my way into heaven. 😁
Please put it all in a nice neat spreadsheet and I'll review it next time I'm constipated. I don't do YouTube University
But yeah... in the end what that all means in the real world is one lube might last an additional mile over another... but only if the planets align on the 38th Tuesday of a leap year.
I ordered the same stuff
I thought you ordered the Rock N Roll Gold? (maybe you ordered that too??)
It says on the label "creates a wet membrane" and I want dry so I went with the T-9.
It's just parrafin wax and a "delivery agent" that evaporates leaving just the wax behind.
It might dissolve some of my hot wax away, but it should replace it with fresh wax.
(that's all complete speculation on my part. I tend to make stuff up. 😁)
But you still need to consider...
