I am new here, dont know how to post it , thanks everyone for sharing!
Welcome Brian,
I use a free hosting site called postimages.org but you should be able to use the picture icon in the text box to upload a pic. I believe it needs to be less that 2mb in size.
Welcome aboard! Here's how I upload my photos, all of which exceed the forum's 2 MB limit in original form:
1. Copy photos to upload to a processing folder I call "copies".
2. Manually reduce each copy to below 2 MB using a combo of cropping and resizing. My Android's built-in photo editor is more than adequate.
3. Start a new post and click the [Attach files] button below the text box, navigate to the copies folder, select the copies to be uploaded, and hit [Send] (or whatever that go button is called).
4. Go back to the text box, put your cursor where a photo should go, click [Insert] on that photo's thumbnail below the text box, and choose [Full] or [Thumbnail] as desired.
You'll figure it out from there. This method's all manual, but it's reliable and goes quickly with practice.
Also an opportunity to put 2 basic photographic principles to work: (1) Fill the frame with your subject, and (2) it's often the crop that makes the shot. A good crop is sometimes all it takes to get under 2 MB.
If you use a Windows based PC, you can simply copy an image from a folder or directory and paste it into your message. It must be less than 2MB in size or you will get an error message.
Or [super]+[shift]+[ s ] to cut a screenshot directly from your pc screen and paste it into your message, it wil upload itself and youre done.
Btw super key is on a qwerty-windows™ keyboard also known with the windows™ flag key
