2018 Rad City chain upgrade
fnkyhd
I just broke my chain so I clown pedaled to the rad shop and got one. He said it should have 122 links but the old one had 118. the new one he sold me looks really cheap and very obviously not as beefy as the original, plus i think i ruined it trying to get it back together. Is there a better quality upgrade? These bikes take a lot of torque and when the electric motor shuts off (which it does sometimes on a hill) there is a sudden surge of torque on the chain. Any suggestions on where I might find a better quality chain? preferably one with a master link! thanks!
my bike has 7 speeds but the KMC 7 has only 114 links
You can buy the 8sp
They're both 1/2 x 3/32 but the 8sp is 122 links
How many speed chain do you need?
The KMC "e" chains are nice
This is an 8 speed.... But they come in all flavors
Ditto on the KMC e chain. Happy with mine. I don’t know why your guy used a chain with fewer links to replace the one you had. That’s sloppy.
You need a couple of tools to change a chain; a chain breaker tool to pop out links, and a master link pliers to remove (and installl) the master link.
Recommend you count the links to make sure you’ve got it right. Do you have the originall chain? If not, don’t use the “side-by-side” method as the clown who replaced your chain went too short (if your information is correct).
following up: i ordered the KMC E8 from Amazon. seller was called "Protea Tools" I received a damaged chain in a package sealed with electrical tape. the chain had the master link improperly fitted and that link was frozen :rolleyes:. sent it back. ordering a new one now. let's see how many tries it takes to get an actual new one!
Last I purchased one it came direct from Amazon and was a few dollars cheaper. Bad timing.
i couldn't find another E8 so I went for the E9. it still has a master link, should be ok if i remove some. will hang it next to the old one to be sure
Nooooooooooooooooooo!!!!!!!!!!!!!!!
6 thru 8 are the same.
9sp are a little thinner.
You can buy it directly from KMC... Give them your email and they give you a $10 discount on your first order.
Shipping is $10...not sure if they collect tax.
ooh thanks! order cancelled in time! 👍 will keep looking. probably a shop around here has one.
Alternatively the KMC X8 is a decent chain.
Not eBike rated but I got about 3000 mi out of them with a 750w mid drive... and there about half the price.
BUT... you may not find it at 122 links as I think the standard is 116. But I've found bike shops on Ebay that sell it as a bulk reel cut.
