Temporary power outages and motor noise
Vic Dupont
Europe
Hi there!
My partner’s electric bicycle is no longer working properly.
The symptoms evolved, but to summarize today’s situation, when riding it after stopping to pedal, motor often won’t turn back on, unless we bring the bike to a standstill. And when motor is on, it makes a lot of noise.
Here’s a video:
Complete history of the symptoms​
For the complete history, my partner purchased it second hand, from someone who seemed very trustworthy and very careful with the bike. The bike didn’t have a scratch and was working perfectly for a week.
The only event we can think of between the moment when it was working and when it stopped was a time when we put the electric bike in the trunk of our car, together with my bike, and at some point my bike tipped and fell on her electric bike. But it wasn’t a big shock really.
After that, the motor didn’t work at all. The display lit fine, but the motor never.
I tried to mess with it, unplugged and replugged every cabled, tested a lot of things. While doing so I got the bike to fall from shoulder height when it was hanging from a low tree.
After all this fiddling, now the symptoms are what I described: when we start riding it the motor starts, when we stop pedaling it stops, and when we start pedaling again it often won’t restart, not always though, .
If we then stop the bike, meaning bring its actual speed to 0, without doing anything else, not changing any controller setting or whatever, and start pedalling again, most of the time it kicks back in instantly.
Conversely, if I keep riding the bike without the motor kicking in, even if I'm going downhill for a few seconds and not pedalling, the motor will not kick back in when I start pedalling again.
It will only kick back in after bringing the bike to a standstill.
Also, when motor runs it makes a lot of grinding noise and big vibrations. The whole back of the bike shakes.
When I hang the bike on the tree again and try to reproduce the issue, the motor noise is significantly lower, I wouldn’t notice that it is wrong. Also it always starts back, I couldn’t reproduce that behaviour when bike is hanging from the tree, basically with no real load. I move the pedal by hand, motor starts, I stop pedalling, it stops, I move the pedal again, it restarts, etc. Basically normal behaviour. Here's a video:
Tests I made​
I did all the tests listed here, except for those that require a device to turn the wheels at constant speed: https://electricbike.com/forum/foru...-motor-s-phase-wiring-hall-sensors-and-wiring. All the other tests I did, and they all passed successfully.
I opened up the motor, suspecting loose magnets. Although I didn’t manage to separate the rotor from the stator, looking at them together I didn’t notice anything weird. This is my first time trying to repair an electric bike, but everything seemed normal. The bike is a foldable Megamo Park and I think it’s a Shengyi DGWX2 motor.
I also checked for broken teeth from the planetary gears but didn’t find anything.
The casing where the gears meet with the wheel had a very slight bit of slightly rusty colored stuff, but very little, and nowhere else.
Hypotheses​
The noise made me suspect a problem with the motor, but intermittent power outages don’t seem to me to be related. Power outages would have made me think of a controller issue.
I would also tend to rule out a battery problem, since the display is always lit no matter what.
Does anybody have any idea what the cause could be?
Thanks a lot in advance for your help!
Rusty colored stuff usually means metal shavings that have been exposed to water. Not good. My guess is a bad bearing causing metal to metal contact somewhere.
Thanks a lot for the swift reply!
I can imagine how that could create the grinding noise, but I don't see how that could cause the temporary power outages. Do you think it could be related?
Thanks again very much for the help!
I have new data, freshly arrived from my latest test: actually when the symptom happens, meaning I pedal, motor starts, I stop pedalling, motor stops, I start pedalling again and motor doesn't kick in again, I just noticed that if I stop the bike completely, meaning I reach speed 0 mph, and start pedalling again, then it kicks back in again.
So it seems it's not a matter of waiting long enough. It seems to be a matter of bringing the bike back to speed 0. After that it kicks back in almost always. Conversely, I can stop pedalling for a while, and keep riding the bike without the motor for a while, it won't kick back in unless I stop the bike entirely. To avoid further misunderstanding: by "stopping the bike" I am only referring to its actual speed, I am not turning anything off, neither controller, nor battery etc. I just reach a standstill and start again, as if at a red light.
Despite the issues with the metal filings inside the motor, I'm wondering if this bike has brake cutoff switches and one or both of them is malfunctioning.
I can't speak from experience, but I believe a controller can start a hub motor in a no-sensor mode. When it gets going, the absence of feedback from one of the hall sensors can make the motor noisy. If the controller shuts off the motor because you stop pedaling, and the wheel continues to turn, I think a controller won't start the motor without feedback from all the hall sensors.
I seem to recall checking hall sensors with a multimeter years ago. It was just practice because I had no reason to think anything was wrong.
This sounds like a Hall sensor problem. They're inside the motor. Falling over should not affect them as they are tiny. PCEbiker put up this nice pic of his motor the other day. You can see three of them on the outer edges of he circuit board.
What could have happened is you knocked the motor connector loose. You can recheck that. Is it a molded 9 pin connector? They need to be well seated.
The unambiguous test here is electrical test of the Halls. It's tricky if you don't have the right equipment, and those 9 pin plugs are impossible to probe unless you made a custom tester.
You got two ebikes? Do they have the same motor connector? What I have done when I had a noisy motor is plug motor A into controller B etc.
Of course there's a risk that you wind up with two dead bikes.
Thanks A LOT for your help guys, I really appreciate it!
About brake cutoffs: good idea. I disconnected them entirely, to rule this possibility out, and unfortunately they're not the culprits.
About hall sensor feedback, it is really interesting to know that this possibility comes to your minds.
It's also good to know about this no-sensor mode startup thing. I don't think it's exactly what's happening though, because sometimes I start the bike, motor runs, I stop pedalling, motor stops, I start pedalling again, motor starts again. It seems that it's only after putting it through hard work such as climbing a little, that the symptom of it refusing to start again happens.
Still it's interesting, it might be part of the explanation I guess. At least it makes me understand a little bit better how it works.
@harryS, About loose motor connector, do you mean the black cable outside? Yes I unplugged it and replugged it several times.
About testing hall sensors, I did all the tests listed here: https://electricbike.com/forum/foru...-motor-s-phase-wiring-hall-sensors-and-wiring
Would these cover the possibilities you have in mind?
Unfortunately I don't have a second ebike :)
Thanks again very much for all your help!
"It seems that it's only after putting it through hard work such as climbing a little, that the symptom of it refusing to start again happens."
I suspect you have a continuity deficiency within one of the fine stranded copper wires in a place covered by plastic insulation.
The 'invisible' broken fine strands of copper change the resistance and capacity / performance of the wire EX: when loaded of hot or flexed
A bent wire, similarly, high and subject to broken strands.
Phase current could heat up a point of resistance. When the motor was acting up, the trouble spot might be detectable by touch or an IR thermometer.
" I just reach a standstill and start again, as if at a red light. "
If one of the ~5V feedback type of stranded copper wires is marginally continuous and regains minimal open or closed continuity enabling circuit to be complete upon stopping.
That particular wire or a complimentary wire could be ready to break internally.
Hi there!
Here are the news.
I spent a weekend on this bike.
The general conclusion is that I didn’t spot anything that seemed to explain the problem.
I checked continuity of the whole hall sensor loop. I checked continuity of all wires coming in and out of the controller. I opened up the motor and didn’t notice anything special.
The only thing I noticed were some of the small black plastic stuff between the magnets in the motor sticking out. I don’t know whether I can or should push them back into alignment.
I also did more testing, and was able to reproduce the issue even without load, meaning I put the bike upside down, turned on pedal assist, pedalled, and sometimes after a while motor refused to start again.
More precisely, here are the tests I did.
First I tried jiggling the motor cable while motor is running. I did that by putting the bike upside down and pedalling. I didn’t see any impact of moving the cable on the motor. It still kept running the same.
Second I opened the controller and checked for continuity between all cables, from their socket to the solder on the board. Everything seemed well.
I checked the controller’s board for anything that looked weird. Didn’t see anything.
I opened the motor and checked for continuity between the wires at the socket and the solder on the board. I did that for all hall sensor wires and the white wire. Basically all 6 small cables.
I also checked for continuity between each phase pin on the cable and the connection with the windings on the motor. One of the winding connection I couldn’t get continuity, maybe because I couldn’t touch it with my multimeter probe, but all phase pins got continuity with one another, and with the other two winding connections on the motor. So I guess it’s just that I couldn’t touch one of the connections with my probe on the motor.
I also checked the phase wires by shorting them manually by pairs, and then trying to turn the wheel. I felt the cogging resistance as expected, whatever the pair. And then shorting all three together, the more constant resistance.
I also wired everything back together, with controller still open, and measured voltage on each hall sensor wire solder, turning the wheel a little bit each time. Voltage oscillated from 0 to 3.28 V alternatively, looking perfectly normal.
Thus it seems to me that the whole hall sensor loop is working perfectly.
Unless it behaves differently with the controller put back into place, and the bike moving.
I also checked voltage at the pedal sensor wire solder on the controller’s board. It seemed to correctly report each time a magnet passes in front of the sensor.
I also looked for shorts anywhere I could but didn’t find any.
Here are pictures of the motor, in case you notice anything:
Do you have any idea what the problem could be, or what to test next?
I was thinking of trying to swap phase wires
, just to see what would happen. I read that I can do it if I don’t put too much load, and monitor current intensity to make sure it doesn’t go too high. Do you know whether in my case I could risk damaging something if I try this?
Any other idea is welcome too.
Thanks again very much for all the help!
Check the solder joints on the third triple on the right as we see the pictures. The exposed leads are longer and may have been stressed. That's all I got.
Two suggestions.
1. Look at the pedal assist sensor and make sure it turns with the pedal. I had one that started slipping and I was losing power every half revolution. The sensor was so old that the plastic had turned brittle,. Perhaps consider swapping in a new one.
2. Change out the Hall sensors in the motor. Honeywell SS41. Easy job if you are experienced solderer. They are open collector, so I wonder why the high value is only 3.28V, Would expect 5V.
Since the bike worked great for a week, swapping phase wires will just make it worse.
Thanks a lot for your replies and your help!
I'll check again the solder joints. But theoretically, shouldn't that already be good since the controller is receiving the correct voltage from the hall sensor wires as I turn the wheel?
About pedal assist sensor, I checked it unfortunately. It's turning, and I also checked that the controller is receiving the signal from it.
I'll try to check why the high value is 3.28V in the hall sensor wires.
About swapping phase wires, the reason why I was mentioning it is because from my understanding, I was thinking that maybe the symptoms I am experiencing are the same as when phase wires are incorrectly paired. I was thinking that maybe the following scenario occurred: the bike stopped working completely because of a loose cable connection somewhere. When I started repairing it, I unplugged everything, and maybe I didn't take note of the correct pairing of motor phase wires with controller phase wires. Maybe they are not supposed to go yellow to yellow, blue to blue and green to green. Since I replugged everything, the loose cable connection was solved, but maybe the phase wires are incorrectly paired, and I now get these symptoms.
What do you think?
Otherwise I was wondering whether it could be that while repairing it, somehow I could have pressed very long on the display buttons, and that would have reset the controller settings, thus changing the correct phase wire pairing?
Again a very big thank you for all the help!
Hi guys!
So I got back home and resumed testing.
Unfortunately, still no clue what is wrong.
First I tested transistors, they seem fine:
Second I tried swapping phase wires. Most combinations didn’t seem to start the motor at all, and the last one seemed to make it harder to pedal than without any assist. It was also making a little bit of noise.
At this point I am starting to despair. I don’t know what else to test. Any idea would be greatly appreciated.
Thanks again a lot for the help!
Hi guys,
I have new info!
I am hopeful that this will be enough for you to know what's wrong, especially the new observations I made with motor running without wheel.
Summary:
1. I was able to fully reproduce the behaviour with bike upside down
2. I did more tests to try and find a bad contact somewhere, to no avail
3. I noticed that controller heats faster than motor
4. I tried running with controller open to cool it, but behaviour was the same
5. I noticed that when I stop the wheel abruptly, motor is more likely to start again after
6. I noticed a slight wobble of the planetary gear plate
7. I ran the motor without wheel, and noticed that the planetary gear plate is rotating slowly when motor is running
8. I also noticed that when motor refuses to start again, it moves a tiny bit, and moves back the opposite direction when I stop to pedal
9. Lastly, I noticed that at the moment when motor starts or stops, the planetary gear plate turns a lot, abruptly
10. I also checked for loose magnets
Here are the details.
1. Problem fully reproduced upside down
I was able to do so by simply switching the bike to an easier gear, thus asking more work from the motor.
In such setting, the problem was fully reproduced: noise louder than normal, and motor often refusing to start again after stopping to pedal and starting to pedal again.
2. Tests for bad contacts
With bike upside down and motor running, we tried moving every cable everywhere, putting controller in different places, etc. There was no change whatsoever to the noise and behaviour.
3. Controller heats faster than motor
While doing these tests I regularly touched the motor's casing and the controller. The controller heated up faster than the motor, even though there was no load on the bike, only the wheel.
After a while motor heated up as well, but controller first, and I would tend to say, controller more.
4. Cooling controller didn't change anything
I tried taking controller out of its case, circuit completely out in the open, and running that way. I was thinking it would cool it down, and thus if the problem came from a thermistor, the behaviour would change.
No change.
5. Stopping the wheel abruptly seemed to help
When doing those tests upside down, after motor ran and I stopped pedalling, if I started pedalling again and motor didn't start, I had two choices:
- waiting for the wheel to reach a standstill by itself
- or grabbing the wheel with my hand to stop it abruptly
I noticed that if I grabbed the wheel abruptly, and then started pedalling again, motor was way more likely to start again. Conversely, if I waited for the wheel to reach a standstill by itself and then started pedalling again, it was much less likely to kick back in.
I thought it looked like the shock was probably putting something back into place.
6. Planetary gear plate wobbles a bit
I don't know whether that's enough to be a problem:
7. Planetary gear plate is rotating slowly when motor runs
I set everything up differently for new tests, and that yielded new observations.
I put the motor on the bike, but without the wheel. Thus I just used the bike's body as a vice essentially.
I plugged everything together, and was thus able to "throttle" by just turning the pedal.
To be clear: the bike's chain wasn't connected to anything, so the only movement came from electricity sent by the controller.
Here's a video showing clearly the motor refusing to start again after stopping to pedal. The noise is me turning the pedal, but the chain isn't connected to anything. Thus when I turn, the motor should start.
In such setting, I was able to observe that the planetary gear plate is rotating slowly when motor runs:
(again noise is just me turning the pedal)
I don't know whether this rotation of the plate is normal.
I am not sure whether the inner part of the plate, with the keyway, is also turning, or whether it's only the outer part. I wasn't able to reproduce it today, and the videos are not clear enough to distinguish.
8. Motor moves a bit when it is refusing to start again
Another observation, which seemed to me very interesting, was that when motor refuses to start again, when I start pedalling, it moves a little bit.
When I stop pedalling, it moves back that same little bit, into the place it was before.
It thus seems that it's trying to start, but is blocked.
I was thinking this would probably make it clear to you where the problem comes from:
9. Planetary gear plate turns abruptly when motor starts or stops
Still in the same set up, the last observation was that when motor starts, and when it stops, the planetary gear plate suddenly turns a lot, abruptly.
It does so in the same direction, whether motor is stopping or starting:
I don't know whether that is normal or whether it's a hint to the problem.
10. I checked for loose magnets
I don't know whether my check was sufficient. I used a small screwdriver and tried to push every magnet towards the center, but lightly, and without separating the rotor from the stator:
I didn't notice any movement.
That's it for the news
Do these new pieces of information give you any hint as to the origin of the problem?
Does it still look to you to be an electric issue?
Thank you again very much for your help!
Hi there!
Here’s a video:
Tests I made​
Hypotheses​
Well, hypothetically, bicycles can take a whole lot of bangs and bumps and potholes and not come apart. If you know there wasn't an impact with a wiring harness where one wire was damaged in the bundle, then I would think toward the battery pack. Kind of like a 240V feed into your home appliance has two "poles". Or two 120V connections at the breaker box where you connect the wire that eventually leads to the appliance outlet, oven, dryer, electric car charger. I would look at the battery connections or pins and then maybe open the battery to see if you knocked something loose. Might have to solder a broken connection, wire, batteries. You might not be getting enough "juice" to make the motor run at normal capacity. A inexpensive voltmeter or multimeter can be very useful trouble shooting electric gadgets. The Ohms setting sends a small current through a non energized wire or circuit and tells you if there's no resistance which gives you a number based on the wire type and length and indicates a closed circuit which is good. And infinite resistance which means an open circuit or broken connection. Checking for a broken connection or infinite resistance you get no numbers jumping around on the screen, just a zero. You can also use the direct current "DC" setting to look at total voltage output on the battery pack and check individual cells to see if they are all uniform or have similar voltages. Just be very patient. The longer the race, the greater the victory. Just time and patience and you will get 'er done.
