Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
Holly s*it! You gotz a FUGAZI!
OK.... there was oil inside the air can and it was a bit darkened from wear. And though I tried to be careful and angle it on disassembly, most of it spilled on the floor. I'd say total about 2ml...Or maybe some of it was diluted grease.
Everything inside looked new so I wiped everything clean, Slickoleum'd all the rings and added the oil that came with the 50hr service kit split between the top and bottom just like in the video. The hardest part is pushing the air can back in place and getting the threads started as there's quite a bit of push back.
Yes you could add oil through the Schrader valve as it's ported directly into the air can... But honestly I don't see a reason to unless you're pissing oil at the seals and don't have time to repair and want to buy some time.
Eyelet bushing went back in place without the tool.
The shock back on the bike and testing in place it felt good and just like my spare shock which by the way is new.
Didn't have much time nor enough charge on the battery for a long ride but I put it through its paces as I aimed for every rut, ripple and road divot on the MUPS and it performed as new if not better on the initial 12mi ride.
SLICKOLEUM RULES!
Maybe I fixed it... Maybe it's temporary... Or maybe I just wasted 2 hours
Anywho, not too concerned... it was an experience and it's working for now. If the issue returns or something else develops, I'll update.
Edit: To further confuse the oil question... The 2016 Monarch repair manual states:
Inject 0.5 mL of Maxima Maxum4 Extra 15w50 or Maxima
PLUSH Dynamic Suspension Lube Light into the air can.
Now the PLUSH description:
Maxima Plush Dynamic Suspension lube is an advanced specialty fluid formulated for high performance suspension systems. Formulated and tested with OEM engineers and designed for use in lower fork legs and multiple other non-damper components. Surface active technology reduces static and dynamic friction and considerably lowers the force needed for easy breakaway, providing smooth action throughout the entire range of travel.
Dynamic Light is a direct replacement for 0w30 in all forks specifying the use of Rockshox 0w30
High performance lube for all lower fork legs and other non damper suspension components, including all Mountain, XC , Gravel, Down hill, Enduro and Freeride (Also approved for use in some dropper post seat designs)
Dynamic lube activates on loaded bushings and seals
Reduces static (stiction) and dynamic (running) friction
Proprietary additive system minimizes wear and keeps the system clean
Long life fluid extends time between rebuilds
Your Viscosity May Vary. . .
SLICKOLEUM RULES!
