Marts,
Thank you so much for your such interesting posts! It has given me a good morning reading!
Let us start with the fitness matters. I have medical conditions that limit my
average leg power to some 80 W no matter how I try. We also have Jeremy who is older than I, still he's zooming his SoCal steep hills with ease on his Vado SL 5.0. There also is a friend of mine (age 48) who took the second place in e-Sprint gravel race (80+ mi, 1,200+ ft) this year riding a Vado SL 4.0; the race was won by a woman who rode a "full power" Mondraker e-MTB. So I'd say Vado SL (2020-2024) is an adequate e-bike for many people.
You ride 50-60 miles often. Any idea what elevation gain are you getting on your ride? How steep the hills are?
Resolving Confusion Related To Names and Model Versions
Vado SL (before Version 2 Carbon 2025)
- 48 V system
- All versions have a true 240 W (mechanical power) SL 1.1 motor
- All versions have a non-removable 320 Wh battery
- Optional 160 Wh Range Extenders are available
- Aluminium frame
- Version 4.0: Less expensive componentry, no suspension.
Version 5.0: Expensive components, Future Shock front suspension, carbon fibre fork
- Non EQ: Lighting - yes. Mudguards, rear rack, kickstand - no.
- EQ: Lighting, mudguards, rear rack, kickstand - yes.
- Tyres up to 42 mm (unequipped) or 38 mm (EQ), gravel type
- Reasonably priced.
Vado SL 2 6.0 Carbon (2025)
- 48 V system
- A true 320 W (mechanical power) SL 1.2 motor
- A non-removable 520 Wh battery
- Optional 160 Wh Range Extenders available
- Carbon fibre frame and components
- Advanced Future Shock front suspension
- Top componentry
- EQ or non-EQ
- 47 mm tyres as a standard
- Deadly expensive
Vado (full power)
- 36 V system
- Always equipped (lighting, mudguards, rear rack, kickstand)
- Removable battery
- Motors, battery, components
- 3.0: max assist 2.8x, max true motor power 430 W, 530 Wh battery, entry level components
- 4.0: max assist 3.2x, max true motor power 470 W, 710 Wh battery, middle tier components
- 5.0: max assist 4.1x, max true motor power 565 W, 710 Wh battery, high-end components.
- Front suspension (performance depends on the model number)
- Suspension seat-post
- Wide tyres
- Pricewise, version 4.0 is the best value for money.
You wrote you would like to ride 20+ mph
unassisted on a Vado SL. It is not easy at all unless you ride downhill or with a strong tailwind
It is because the air drag becomes the limiting factor around 20 mph. My 48-yo mate can achieve some 18 mph without the assistance on a Vado SL EQ.
You wrote "gnarly tracks". If you can ride them on your current e-bike then...
My experience is a Vado SL (especially SL 5.0) handles pretty well in rough terrain while the big Vado is not the best suited for off-road. However, I can only say it for myself but I am not a good MTBer
Vado simply feels too heavy for rough terrain for me.
Taking e-bike on a train. Of course, it is so easy to take the lightweight e-bike on the train but again, I'm taking my heavy Vado on the train as well. A little bit harder but I often use the Walk Mode to roll my heavier Vado up the stairs in case my big e-bike is fully loaded with panniers!
Range!
Specialized Turbo e-bikes have one of the most sophisticated electronics in the market.
- You can fine tune any of the three presets (ECO, SPORT, TURBO) to precisely set the Assist and limit the Max Motor Power in Specialized App. You can set it for Long Range or for Racing (figuratively speaking). So you can have full Turbo for steep climbs and your own minimum ECO assistance setting for very long rides. For instance, I set the assistance as low as 15/20% for my full power Vado if I want to ride together with casual traditional cyclists on asphalt.
- You can tune the assistance 'as you ride' from the handlebar remote in the unique Micro Tune mode (10/10 to 100/100% in 10% increments). Range and Range Trend display helps you setting the optimum assistance
- You can set Smart Control in the Specialized App so you will ride for a predetermined Distance and Elevation Gain and still return on the battery; the App will adjust the assistance online as you are riding!
In the light of the above, the published Range figures are rather an indication than a guaranteed promise
IGH? I do not recommend it
It simply degrades the performance, and makes the e-bike even heavier
Frame size
Believe it or not, but size XL is as unpopular as you can get a Specialized e-bike in such a size easier than anything on Black Friday sales.
Important: Specialized has two pools of e-bikes. One is for online sales and another is reserved for Dealers. If you cannot find what you need online, ask your Specialized dealer!
I am not sure if I covered all your points.
What I think is you decidedly need to do demo rides to determine your real needs!
