20kg will change it's personality, as Mschwett says.The spec is good!
Turbo Vado SL 2 5.0
Nothing delivers more power, speed, and range at such lightweight than Turbo Vado SL 2. It’s a high-performance machine carefully engineered to make fit...www.specialized.com
I still own two good Specialized e-bikesWouldn't exclude the CF though. One needs to try something new sometimes
20kg/44lbs won't ride as well with power off as the SL 1 bikes did. So finding a sweet spot of low assist to counter the weight and not use too much battery will be key. Especially in hilly areas, lot of weight to drag up. Guess that's where the 55nm motor comes in. Wonder if the original range extenders work with it? Or with 504wh if you'd even need one?
