Unspeakable things. Don't do it!What's the penalty for posting if we haven't bought the correct one?
This works great on my Abound.3 pin male..it needs to be able to clear the trigger shifter also?
please dont reply if you have'nt bought the correct one
Spokewrench
If you didn't know, you can have a adjustable cruise control throttle with that model, just remove the small plastic sleeve that fits in the twist part, then jamb to two parts together, this will create friction between both parts and hold what ever speed you want makes for very long battery life when you are traveling long distances etc.
I run the same throttle only on the left side on both of my rides. ymmv
				He asked if we'd bought the correct one, and I believe I have. There are 6 possible ways to wire the three pins, so I didn't know what would work on my Aventon until I read that this one worked on an Aventure. It stands to reason that all Aventon controllers would use the same throttle wiring because otherwise there would be a lot of hassle over replacement Aventon thumb throttles.Y’all are heading to the dungeon. The OP specifically asked about the Level2 and no other bike.
