Deacon Blues
It looks like you've got more room between the top of the motor and the frame, compared to my UC Pro.
Why is your frame so damned clean!Ok.... My turn @ 1400mi.
First try I had to retreat as the chain ring lock nut wouldn't budge and after 10 minutes of putting all my spaghetti arms had in them.. I warped the p.o.s flat wrench that Bafang provides with the BBS02B.
Ordered this 1/2 drive Socket
View attachment 170603 which arrived in 10 days and I spun off the lock nut in 5 seconds.
There was fair amount of factory grease.... at least more than I've seen in other pics. View attachment 170597
Cleaned it up nicey nice... View attachment 170595
I'd say I added back about double the factory amount. Basically I lightly coated all surfaces and packed between the teeth of all the gears. I used Mobil SHC100 because I had almost a full tube on hand left over from my BBS02B. Additionally I've read it's similar to the factory grease and less chance of contamination from grease incompatibility if any remnants exist.
My gasket looked just as good as the two replacement ones I had on hand so I didn't change it this time around.
One things no one mentioned in any of the videos I watched...
Careful with this ring that sits on top of the large gear bearing as it's delicate. Mine fell off when I split the case leaving me not sure where it went.
On assembly I sat it on the controller side and held it in place with a thin coating of grease.
Now for the results...
I went for about a 20mi ride and it was noticeably smoother with less micro vibrations. As for the noise that too was noticeably less, especially at low power output.. Almost silent say below 100w. At higher output the sound changed to a deeper more pleasing tone then before but was still pretty audible. Went from a GRrrr sound to more of a RRrrr sound. Or from a super charged electric can opener to a high end stand mixer.
Didn't get arrested during any of this.... So I guess it was time well spent![]()
Yeah it wasn't too bad.It looks like you've got more room between the top of the motor and the frame, compared to my UC Pro.![]()
I always try wash it before take things apart. I find it makes it easier to work on things. Real cold now, I had to pass a hose from the laundry room slop sink outside to gets me some hot water out there.Why is your frame so damned clean!
Because he's better than you and maintains such a rare and rather valuable bike appropriately?Why is your frame so damned clean!
Sounds like you've been freebasing your chain/ gear lube, suspended in a high molecular weight refined paraffin carrier again.Because he's better than you and maintains such a rare and rather valuable bike appropriately?
Your turn: Why is your (imaginary) bike so ethereal, vague and intangible ?
Fn'F
Hot water bath for easier removal on BBSxxI tried out the new quieter gears from Green Bike Kit. My results are over here:
https://forums.electricbikereview.com/threads/m620-new-quieter-gear-comparison.54786/
Pulling the rotor is like pulling teeth - the magnets are super strong. Calibrating the rotor with the fully cracked X1 Tool was simple - just click the button.
Thanks for the tip! I'm going to try the new rotor and third gear.
TY. Going there now - hoping you documented the menu sequence for synchronizing the rotor.I tried out the new quieter gears from Green Bike Kit. My results are over here:
And don't mix them or you'll end up with salsa in there!Ii you have the avocado coloured grease in your M620. Best to re grease it with red grease. My 1st ultra M620 I waited 3000 miles to lube and I ended up having to rebuild with new gears the rattle and high pitch noise of dry gear drive was too loud..
I wish Pushkar had designed the UC Pro frame with a half an inch more motor clearance. It would have made a world of difference when installing the motor.Yeah it wasn't too bad.
The only obstacle was the internally routed Rohloff shift cables and rear brake line that pass through the space as well. Had to keep wiggling all as I pushed it into place. Got some long/thin screw drivers through the bolt holes first which allowed me to take my time.
As an electrician in a former life... I couldn't agree more.I wish Pushkar had designed the UC Pro frame with a half an inch more motor clearance. It would have made a world of difference when installing the motor.
Side note: I recently came across a Chinese company (Waltly) that makes a custom titanium frame that is very similar to the WW's UC Pro frame.
100mi Update:Ok.... My turn @ 1400mi.
Careful with this ring that sits on top of the large gear bearing as it's delicate. Mine fell off when I split the case open leaving me not sure where it went.
I considered doing the same but decided against doing so. As you can see from my pics there was a fair amount of grease in there from the factory though some have been less fortunate. I did mine as a curiosity and possible sound mitigation than wear prevention. I'd consult WW as their motors are custom and they may have addressed it already.Just got my Hydra! Still putting it together. Should I grease the motor before her maiden voyage??
Thank you. I'll reach out and ask. WW is sadly in the process of closing up the shop. They will continue to support previous customers.I considered doing the same but decided against doing so. As you can see from my pics there was a fair amount of grease in there from the factory though some have been less fortunate. I did mine as a curiosity and possible sound mitigation than wear prevention. I'd consult WW as there motors are custom and they may have addressed it already.
Good luck with the Hydra... nice looking bike.
Some have questioned if WW is still in business, seems it is.
Sad...Thank you. I'll reach out and ask. WW is sadly in the process of closing up the shop. They will continue to support previous customers.
My bike was ordered a very long time ago. Very happy to finally get it
Glad to hear you finally got your Hydra.Just got my Hydra! Still putting it together. Should I grease the motor before her maiden voyage??
Hey buddy, I don't wanna hijack this thread. I'll make my new Hydra post!Glad to hear you finally got your Hydra.
Last year, when I re-greased my UC Pro's motor, I also re-greased my Hydra's motor. While my UC Pro's motor has almost no grease my Hydra's motor had lots of grease (red coloured).
Does your Hydra have a regular derailleur setup?
Too bad about WW's demise. I'm actually surprised they lasted as long as they did.
