Fryer is back from the shop and it works perfectly.  He did recommend having the thermocouple replaced but it's functional for now.
I have a natural gas wall furnace to heat my small house.
It uses a thermopile, which is just a "pile" of thermocouples stacked together to generate more voltage to operate the thermostat.
My wall furnace has since been banned because it isn't efficient enough (it draws 85,000 BTU, but only puts out 65,000 BTU.   The rest goes up the chimney.
BUT,.. my furnace doesn't need electricity to operate.
I've got heat when the power goes out where 99% of other homeowners don't have heat until the power is restored.
This is my thermostat, complete with a mercury switch,..
That's enough mercury to poison a small lake.
A digital thermostat doesn't work.
It draws too much current and the voltage drops to zero.
And it uses batteries or house current.
My furnace has been running since 1942 with no external power.
The thermopile only puts out ~0.7 volts, with VERY Little current behind it.
I had to replace the wiring with thicker wire because the wire had too much resistance and the voltage/power was lost.
Even static electricity is enough to drain the voltage in the winter when the wiring is dusty.
