What seals? Are you talking about the rotor inside the motor? I think OP means brake rotor.you can destroy the seals if you use the automotive brake cleaner. Plus it strips the bedding material off too. way overkill.
Indeed!99.9% isopropyl alcohol is what I use when my brakes get squeaky.
Brillo pads.. wet the pads, put them in the brake caliper and ride for 1 minute.
Steel wool if that doesn’t work!!
Brillo pads work to remove caked on, aged grease stains in pots & pans, disc rotor grease is easy for Brillo.
if you have grease on your rotors something is wrong.Brillo pads work to remove caked on, aged grease stains in pots & pans, disc rotor grease is easy for Brillo.
the seals in the caliper of the brake. if you clean the rotor while its on the bike and get it into the caliper that could cause issues.What seals? Are you talking about the rotor inside the motor? I think OP means brake rotor.
