Jeremy McCreary
Bought it anyway
- USA
- City
- Carlsbad, CA
Q: Thought my thumb throttle was all-or-nothing, but turns out that it can be feathered over a very narrow range of middle lever positions. Any electrical reason not to take advantage of this?
NB: Not looking for permission or approval to want or use a throttle, please. Just an answer to a strictly technical question. Thank you.
Background: Wife and I have identical torque-sensing 2023 Surface 604 V Rooks with 500W Bafang G020 rear hub motors. I use my throttle a few times per ride for instant bursts of speed. She uses hers to augment the PAS for prolonged periods while still pedaling, as her knees are even worse than mine. Both of us always pedal.
NB: That's just how she rolls. Trust me, trying to litigate her riding style will do none of us any good.
So, asked her how she managed that with an all-or-nothing throttle. And she said, "What are you talking about? I can get as much or as little help from it as I want."
Well, sure enough, she's right. If 0% is throttle lever not depressed, and 100% is fully depressed, you can get a smoothly progressive boost in motor power, all the way to full motor power, over roughly the 40-60% lever range. And with practice, that's actually pretty useful.
Now, if a lot of amps were going through that thumb switch, feathering power like that would probably be a bad idea from a purely electrical standpoint. But guessing that the thumb switch just provides a low-voltage, low-current signal to the controller. Correct? @AHicks , @m@Robertson?
Many thanks for your technical help on this!
