newheights
- USA
What are the limitations of the bafang hub motor in the aventure.2? I am more familiar with mid drive motors, and was under the impression hub drive would not work as well for steep prolonged grades. I was told otherwise by a LBS selling the aventure.2.
For example, could the hub motor handle an offroad 11% average grade for 2.4 miles while loaded with 350 lbs? I have tried this with a brose mid-drive 90 nm and was able to manage it ok. I was previously told the hub motors need to keep a certain speed up to maintain optimal RPM up or they'll lose power under heavy load, as compared to mid-drive which can keep high torque output at lower speeds due to using the bikes gearing, is that accurate?
Thanks for any insight.
