Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
Where's the photo of your SL, Radhika?
			Here it is!!Where's the photo of your SL, Radhika?
				 northstbags.com
					northstbags.com
				Congratulations Radhika!Here it is!!
I will take some photos outdoor this weekend and also share!
That went way over my head!!Congratulations Radhika!
Now, you order an SL Range Extender, which is incredibly cheap now in the U.S. And an SL Cable (Road) as well as the SL Y-Cable for charging
 What are all these cables you talk of? Hahaha
 What are all these cables you talk of? HahahaThis is so helpful!! Thank you so much for the detailed description and pictures!OK! As you might already know, the SL Range Extender is an extra battery in the form of a water-bottle. Its capacity is half of the main battery.
When you order the SL Range-Extender Battery, it comes together with a water-bottle-cage (which you attach to the bosses at the top tube of your Vado SL 5.0 ST), and with a rubber band included.
You would install the water-bottle-cage for the RE in a different place than I did it as the frames of our e-bikes are different).
You need to buy this item, too:
This cable is for connecting the RE battery to your e-bike.
What you would get with these two purchases is:
The above would be enough. However, you might want to charge your Vado SL main battery and the Range Extender at the same time. Then you need this as well:
- Range Extender Battery
- Water-Bottle-Cage
- Rubber Band
- SL Range Extender Cable (Road)
Why would you need a Range Extender in the first place?
For longer, faster, and less exhausting rides. I recommend going for the Range Extender because that stuff is on SALE, and only in the United States!Don't need, don't buy!
You have two sets of bosses: one on the bottom, and one on the top tube. I guess you install the RE on the top tube and a side-loaded water-bottle-cage on the bottom oneI now need to find another spot to keep my water bottle now because I have the step-through model
That’s a good idea. I will get the RE first to set up as an anchor and then figure out the restYou have two sets of bosses: one on the bottom, and one on the top tube. I guess you install the RE on the top tube and a side-loaded water-bottle-cage on the bottom oneAsk your LBS when you are collecting the goods! Note: The name is Specialized Zee Cage II. You get one together with the RE.
Requires quite a leg swing?I use this one and it works for me can be removed and carry
There are multiple companies that sell exactly the same things. And there are a lot of companies that have produced interesting outside-the-box bike bag products that are very interesting. To me, honestly I think Ortlieb makes good, basic stuff but kind of misses the boat on what people actually need and use. And their stuff is overrated and overhyped by many people online.It is hard to overtrump Ortlieb
In Europe?There are a number of companies experimenting with making quality bike bags from recycled materials at lower costs.
There are a number of companies using ultralight materials, where appropriate, for bike bags to reduce carrying weight and often cost.
There are a number of companies, mostly cottage industry companies, making very highly functional bags that work well with modern bikes and modern people.
Yes, in Europe.In Europe?
Could you be so kind and provide direct links to Pannier-Backpacks from any of those companies?Yes, in Europe.
A quick look around found:
Straight Cut Design, Edinburgh, Scotland, UK
Aravis Bag Works, London, UK
Traag Bags, Vienna, Austria
Von Berg Bags, Graz, Austria
The kindest, most generous, most loving word in any language is "Look!"
I found this without much trouble (unfortunately in the UK):Could you be so kind and provide direct links to Pannier-Backpacks from any of those companies?
(Need to mention it is not easy to import anything from the UK to UE post-Brexit).
				 twowheelgear.uk
					twowheelgear.uk
				Thank you!I found this without much trouble (unfortunately in the UK):
What was the original material used for the sidescreen storage bags? A few vendors are selling Mohair bags, but was this original material?OK! As you might already know, the SL Range Extender is an extra battery in the form of a water-bottle. Its capacity is half of the main battery.
(You would install the water-bottle-cage for the RE in a different place than I did it as the frames of our e-bikes are different).
https://www.burujtextile.com/product-category/storage-bags/
- Water-Bottle-Cage
- Rubber Band
What specific pannier are you asking for?What was the original material used for the sidescreen storage bags?
