smorgasbord
- USA
As part of getting ready for the riding season, I've been going through the bikes making sure everything's setup right. You may have seen my threads on brakes (success!) and Bafang (Ultra) speed sensor (waiting for part to arrive).
Now one of the bikes on a test ride is skipping with high power in the top two gears. This is the SRAM 12-speed GX setup (10-50 cassette) What should my debugging steps be?
0) Drivetrain (chain, cassette, derailleur, shifter) are the same age - about 1500 miles. Seems too soon to be wear related.
1) I suppose checking the derailleur setting, especially the "B" screw is the first step. Any advice there beyond using the SRAM plastic gauge thingy?
2) I'll check for chain wear, but again, I don't suspect anything there.
3) There's no clicking while in any gear - that is, the derailleur appears to be centered well on each sprocket and it's not trying to shift up or down on its own.
4) I should probably check the hanger for being bent, but I don't know how that might have happened while the bike was stored.
5) I suppose it's possible the derailleur cage is bent, too, but don't know how to check that.
Anyway, if you've got suggestions for what to check (and in what order!), I'd be most appreciative.
