Douglas Ruby
 - USA
- City
 - Groton
I just purchased a brand new screaming yellow 2022 Turbo Vado SL EQ  and in the process traded in my "ancient" original 2015 Turbo (the first one purchased at Goodale's in Nashua, NH). I now have about 500 miles on my Vado SL and would like to make a few comparisons with the 1st generation Turbo. My comments comparing the two bikes have to take into account mods I made to the 2015 Turbo which included:
Things that are a wash between the two bikes include brakes (both are good considering I had Kwik Stop pads on my old Turbo). Riding position is very equivalent. I appreciate being able to move my snap in Racktime bag over to the SL. Location of controls made changing over easy.
Now we come to the things I find not as promising. The "low torque" (35Nm) motor requires that one maintain a higher cadence in order to optimize power output and consumption of battery. I find my average cadence on a ride has risen from around 75 rpm to 82-85 rpm. Overall, the Vado SL does not feel as powerful nor as fast as my base Turbo was. The Turbo had a 200W hub motor that would easily peak above that. I generally could maintain a 20 mph average on a ride if I rode in full Turbo mode, where I find my average speed over a similar course at full turbo in the Vado SL is closer to 17.5 - 18.5 mph. This also has an effect on range. Using just one range extender in shared mode with the internal battery, I have seen a calculated range of around 30 miles - 60 miles. The longer distance was calculated based on riding a 27 mile rail trail loop, keeping our speed at or below 16 mph, and using either ECO (50%) or SPORT mode (70%) . The shorter distance was based on a 25 mile loop with significant climbing and maintaining the maximum speed that I could, mostly in full Turbo mode. When the battery was new on my old Turbo, I could generally count on a range of 50-55 miles with a substantial percentage (50%+) in full Turbo mode. This did decrease over time to around 45 miles.
The gearing on the Vado SL 5.0 is MUCH better than the original 10 speed 11-32T with 48T ring on my Turbo, but given the difference in motor power, I consider the 12-spd SRAM 11-50T with a 44T chain ring about a wash with my modified Turbo with its 11-spd 11-42T and 48T ring. I have found that the Vado requires a high spin rate in 11th gear (95rpm +) to hit 28 mph. Using 12th gear makes me feel like I am likely to drop below my comfort zone. SO, I am now experimenting with a 46T chain ring in hopes that I can hit the assist cutoff of 28 mph at a lower rpm in 11th gear and save 12th gear for descents (which is how I set up my Turbo for its 10th/11th).
Final comment...The Turbo Vado SL is MUCH, MUCH easier to work on. The fact that it uses standard bicycle components (wheels, hubs, etc.) and is still fully supported by the vendor makes this a pleasure. Lifting it into the shop rack is easy. Taking out the rear wheel for service, cleaning, or changing tubes is an order of magnitude easier than the old 2015 wheel hub. Getting it into the bike rack on my car is also much easier.
Again, overall, I like my Vado SL and am very pleased. I hope to put many more miles on it.
			- Optional factory fender and rack kit
 - Snap in Racktime rack bag
 - Update to Turbo S 691 Wh battery with bluetooth
 - Update to 11-spd Shimano Deore XT with 11-42 rear cluster
 - Kinekt seat post and Shock-Step stem
 - Other minor changes to brake pads, handlebar instrumentation, lighting, etc.
- Switch to narrower carbon fiber handlebar
 - Switch to Specialized CG-R carbon seatpost.
 - Move handlebar instrumentation from old Turbo (Garmin Edge 1000, add'l flashing headlight, taillight, etc)
 - Move rackbag from old Turbo
 - Two Range Extender batteries.
 - Gearing change (more on this later)
