When I looked at specs for the (USA) 2022 Turbo Vado SL, I couldn't find the actual motor strength listed. Can anyone confirm? Thanks.
Any SL 1.1 motor has the nominal power equal to its max power, and it is 240 W (mechanical) at 35 Nm torque.
I'm glad to hear it all worked so well for you! If I had to ride against such terrible wind, I would have used Turbo myself.
As I said before, the 25 km/h restrictor is a game changer. If it were the U.S. Class 3 Vado SL (or a derestricted e-bike), you might have used the whole battery charge for the ride at a minimal gain with the speed under the conditions described. As it is in your situation, it looks there's no need to worry about your battery in the long run!
I admit I have derestricted my Vado SL because my bad legs don't let me ride unassisted. The same bad legs and the need to conserve the battery charge make my rides slower (that is, I rarely exceed 25 km/h in real life but the motor works all the time).
I was on a 63 km ride yesterday. The assistance was 60/60% Sport. I use Range Extenders in "Fully Discharge RE First" mode to save the main battery. The average speed was only 21.5 km/h (even if the bike was derestricted) and I only can tell you the main battery would not be enough to complete my ride! Different riders, different needs.
I forgot to look but made it home in similar time 42:09 with the strong wind - I used turbo the whole way and found another rider for half the ride who provided a nice slipstream 😂 and still had plenty of battery power when I got home - a great outcome - no extra charger/range extender needed at stage! Average speed 24.6 for 17.3 kms
A question: I have the Vado Sl 4.0 EQ with Shift Levers Sram NX, 11-speed, multi-shift; Chain KMC X11eT, 11-speed.
I was riding up a hill I believe in the lowest gear in "sport" mode when the chain came off. I had a devil of a time getting it back on. I couldn't get the front of the chain past the black ring that protects the chain. The chain wasn't stuck but the space between the ring and the bike was tight enough to keep the chain from passing it. The Sram doesn't have a clutch, but it has a spring that can be moved to create slack in the chain. I didn't see a way to lock it in place to maximize the slack so that made it tricky as well as one hand had to hold the chain in the "slack" position. I did eventually get it back on, but I'm not even sure exactly how I did it. Is there a trick to doing this? Any thoughts on why the chain came off? Also, as I didn't remember for sure what gear the chain was on I just replaced it in the middle in the rear. I assume that doesn't matter as I was able to shift to the high and low limits. As there is no gear indicator am I correct that that it just shifts until it hits each limit so essentially resets itself to the correct position?
Thanks for any advice you guys might have.
Can't help with getting chains back on. My Creo now has a small thingie mounted to keep the chain from jumping off (and getting jammed between the chainring and the motor housing). It just takes fiddling and as you found - Wowwie - it is back on!!!
But, yes, the chain will self-correct as you spin up/down and change the gearing so that it will wind up in the correct position.
There should be a little button to press, that holds the derailleur in position after you push it forward, so no need to hold it with your hand.
I had the same thing happen to me, it's very tight between the chainring and the motor housing as you say, but using the button to hold the derailleur forward to give some slack, helped to get the chain back on after pulling it free.
Thanks. Just took a look and saw the button and confirmed how it works. Good to know. Still I did scratch the paint slightly getting it out. Seems like a design flaw.
Me too, like you say, definitely a design fault. Hate marking the paintwork, but had to get it out!!
Has anyone else installed a chain catcher on their Vado Sl and if so where is it installed and how is it working? Any downsides to installing one?
Not for a vado, but for one of my ebikes I installed the Third Eye chainwatcher (spelling?), and it helped tremendously for preventing chain coming off!
No need in my case. As long as the derailleur clutch is on, the chain has never dropped on my Vado or Vado SL. A single chain drop when the clutch was incidentally not engaged.
Has anyone upgraded their 4.0 SL with any of the following:
1) Enve riser bar (I saw one on an upgraded Orbea alloy MTB while out riding yesterday, and thought I might like one for dampening, etc.);
2) Carbon fork from the 5.0 SL model (if so, could you please provide the P/N?);
3) Future Shock 1.5 from 5.0 SL model (if so, could you please provide the P/N?);
4) MasterMind Turbo Control Unit (TCU) from 5.0 model (Specialized told me this isn't compatible with the 4.0, but I've yet to confirm whether this is correct);
5) 1x12 drivetrain (for added gearing, which I would use and enjoy as I'm regularly topping out at the highest gear; I particularly like SRAM's XX1 1x12 drivetrain);
6) Carbon rims.
Hi everyone,
I've completed several upgrades since my post above. Here's a list of what I've added with some LBS help.
*Enve carbon riser bar.
*Carbon fork (same part from 5.0 model).
*Future Shock (same part from 5.0 model).
*Redshift suspension seatpost.
*Sella Italia Diva Gel Ti Superflow saddle.
*Niterider Lumina headlight.
*Spurcycle bell.
*JBL portable waterproof bluetooth speaker—allows me to jam out to SiriusXM radio while still being aware of my surroundings 🎶. This particular model is marketed to kids but, from the reviews, many adults use it too. It has a strap that wraps around the bar and snaps on and off for stowing and charging. It's also in keeping with my bike's color scheme. I absolutely love it!
FWIW, I bought my bike direct from Specialized and was told at the time of purchase that it "wasn't possible" to do the upgrades I just completed. Frankly, I thought they were full of sh*t and I felt as though I was being pushed into buying the 5.0 stock model when that was not what I wanted. Since purchasing my bike, I found a LBS who has been terrific to work with! They just completed the fork and future shock swap and, in my view, the price was a steal. I was somewhat dubious about how the black fork would look on the bike, but I actually like it better with the modification—both aesthetically and functionally. If you've owned a carbon bike, you'll understand. For anyone looking to modify their Vado SL 4.0, call around—my closest shop wanted an arm and a leg to do the upgrades, but a shop farther away was super to deal with and offered a great price while throwing in labor, etc.
Have a great day!☀️
I had my LBS install one for me — there's a specific Specialized one — after I dropped my chain twice in the same week. It jammed both times between the crank and the frame. The second time it would not come loose and I had to call my wife to come get me. Thank goodness I was on a dirt road and not a trail. So far so good.
Here's what the TOGs look like mounted. Note that I rotated my shifters upward to compensate for my bad thumb.
Hi everyone,
*Spurcycle bell.
Have a great day!☀️
Congratulations - looks like serious upgrade. Could you post some pictures?
Also, do you know what is weight benefit of changing alu fork with carbon + Future shock?
And what is the price level of fork+shock? Probably future shock is version 1.5?
Thanks
Hello from UK. I finally managed to get my hands on Turbo Vado SL 4.0 EQ.
Last year I was frantically trying to get one and finally gave up and bought a Orbea Vector 15 (not an ebike). I use it for commuting once a week (10 miles each way), involves 2.5 miles of 60mph road and rest is a mix of speed restricted (30mph) road and cycle path. As part of my commute is adjacent to open fields, I get serious headwinds. A month ago, I developed Achilles tenditis and had to cut back on cycling - I think its on the mend! I'm hoping to use the new bike to ease commuting.
Cycle is sitting in the garage - its the variant with SRAM groupset, I also bought a range extender, not sure if I would need it. I have also purchased additional D- lock and a lock for brake disc.
I'm used to Continental Gatorskin tyres due to punctures with a few other brands, unfortunately they only go up to 700-32c.
Are the stock tyres - Nimbus II (black belt) reasonable?
Has anyone swapped the 700-38c for a smaller size say 700-32c ?
First of all: Congratulations and welcome to the Club!
It is counterproductive on an e-bike, causing wrong readouts of speed, distance, and odometer, and triggering the 15.5 mph speed limiter prematurely!
I didn't like them. Currently I'm riding Specialized Pathfinder Pro 2Bliss 38-622. Very fast on the pavement, supple on gravel, and puncture resistant.
It is a very good addition! Using Mission Control app, you can set "Discharge the Range Extender first" option. As long as you do not use too much of assistance, you might be able to complete your commute on the Range Extender only. As you know, batteries degrade with the use. If you would consistently use the Range Extender (and, occasionally, the main battery), you would preserve the main battery for a very long time, making the RE degrade slowly over the time, and the RE is relatively cheap.
Have you already bought a rear-view mirror?
@Stefan Mikes Good point regarding using the RE. I'll look into the above tyre recommendation.
I have stayed away from Rear-view mirror, might have to re-visit it later. I prefer to be lit up like a christmas tree with all the high visibility paraphernalia.
Not sure I understand why the speed readout, distance etc would be different for a 700-38c vs 700-32c both have same diameter. Probably my flawed thinking process.
The e-bike computer measures the number of rear wheel revolutions per time unit. To get the speed value, the rpms need to be multiplied by wheel circumference figure that depends on the wheel size. Contrary to what you think, both wheels have different size.
The universal code for wheel size is the ETRTO. Your original tyre size is coded as ETRTO 38-622, and the alternative you propose is 32-622. Both wheels have the same rim diameter (622 mm) but the tyre width and height is 38 mm in the former case, and 32 mm in the latter. The original wheel is higher and with greater Wheel Circumference.
-------- TL;DR ----
Vado SL 4.0 EQ has the value of 2180 mm as Wheel Circumference coded in the system. Meanwhile, the WhC for 32-622 is 2155 mm.
Assume you have ridden for 100 km (using metric units here). With the 38-622 tyres, the wheel made 100000 m / 2.18 m = 45871 revolutions.
Now, change the tyre to 32-622. To ride for 100 km, your wheel must revolve for 100000 / 2.155 = 46403 times.
The Vado SL computer thinks your WhC is 2.18 m. Multiplying... 46403 x 2.18 = 101158 m = 101.15 km. You get 1.15 km discrepancy for the daily trip meter and in the odometer.
Now, we can say the ratio of Wheel Circumferences here is 2.18 / 2.155 = 1.011, It is 1.1%. The bike "thinks" you are riding 1.1% faster than you actually ride, reports higher cruising speed, and cuts the motor off earlier than it should.
You could say the difference is so small you do not care. If so, go with skinnier tyres!
