Do you have the URL to the bag on the Amazon UK website?I'm a bit late to the conversation here I'm afraid ... I've just got the bag shown in the photo from Amazon (UK) where it sells for about £20. There are broadly similar bags for about £14 if you look around; although the size is the same (2.4 litres - enough for a phone and lightweight jacket and a chocolate bar or two) they don't appear to be quite as well finished. The bag straps onto the handlebars (velcro and pretty secure) with an additional strap around the light bracket and cabling. The latter strap isn't tight and carries no weight. The zip claims to be waterproof but I have yet to test it.
As you can see, the light is clear of the bag and not obscured.
Hope this might be of some help
And now back to your normal service ...
Was your Como on warranty? How was the issue handled?Specialized Como 4.0 (the motor died).
Indeed, and this didn’t put you off diving into a vado SL?Was your Como on warranty? How was the issue handled?
Thank you.Congratulations on your purchase.
Which chain cleaner did you get hehe![]()
You'll need to figure out how to use it with a mid-motor e-bikeThank you.
I haven't ordered the chain cleaner yet, just put it in the cart. It's this one recommended by the mechanic at my local ebike shop:
CHAIN AND DRIVETRAIN CLEANING KIT
I’m in the USA so share the experience at higher speeds. I bought my Vado SL to be able to ride the longer distances my local routes require. Distances I couldn’t ride one my analog bike. I was riding that analog bike at average speeds of 12-14 mph. I ride the SL at 14-16. This is faster than most of my analog riding neighbors, so more than adequate.I’ve to express a little bit my disappointment about the Vado SL, at least about the European version limited to 25km/h.
While the limited Creo encourages you to pass 25km/h, the limited Vado SL does not or a lot less. At least for a “medium fit” rider like me the gain if it’s flat is often so small, that it’s not worth to push yourself. So instead of cycling 27km/h on your own you often prefer to be lazy with 26km/h and still with motor. While you ride with 29 or 30km/h on your own there with the Creo and would never think of going down to 26km/h.
This way for me the Vado SL is only a nice light eBike, but still has the annoying “25km/h wall” like other ebikes, maybe a little bit less terrible. With the Creo I feel nothing like this.
Of course this effect appears only with the European limited Vado SL versions. Also only for medium fit riders, really fit ones will pass 25km/h by far also on a Vado SL and weaker riders won’t pass 25km/h even on the Creo.
I don't think so. Imagine your Vado SL motor turning of always at 14mph. What would happen? You would mostly ride at 14mph with little own effort but rarely go up to 15 or 16mph.I guess my needs may differ from yours.
I think it‘s situational. The 20km ride to work yesterday, I used 17% battery. Motor was off for 78% of the time. The way home has more uphill, but I had strong headwind too, so that used 52% battery. Usually it only takes 25% but I needed the full assist (70% of the ride) to beat the wind and have some legs left for the ascent (towards the end of a 20km ride).I'll describe it positive. The Creo has the potential to let you forget the 25km/h limit completely, the Vado SL not for most riders as it's too slow.
I hadn’t looked at it that way. 25 km/h is essentially my cruising speed here in Virginia. Not much effort required. The 45 km/h assist limit on cycling trails here in the USA does make more sense since most local road bike riders appear to easily ride at least that fast. I’m only faster up hill. Sometimes. For me, my Vado SL is plenty fast.I don't think so. Imagine your Vado SL motor turning of always at 14mph. What would happen? You would mostly ride at 14mph with little own effort but rarely go up to 15 or 16mph.
Honestly spoken, my complaint is not against the Vado SL, it's about our stupid 25km/h limit here. The Creo suffers the same restrictions here but due to it's faster character as a racing bike you feel it a lot less.
Maybe you're right and I'm too impatient. If I ride my Vado SL for a longer period and in different areas there my apperar more use cases or situations where it's great.I think it‘s situational. The 20km ride to work yesterday, I used 17% battery. Motor was off for 78% of the time. The way home has more uphill, but I had strong headwind too, so that used 52% battery. Usually it only takes 25% but I needed the full assist (70% of the ride) to beat the wind and have some legs left for the ascent (towards the end of a 20km ride).
On other days (with no wind) it‘s easy to hit 30km/h in both directions.
Yeah, Germany. Though I don‘t mind going under 25 with motor off..
So you're as well under the 25km/h limit?
