Need help Identifying this rear HUB motor
GoinGrey
Recently purchased a Kent electric bike. In their description it stated 350 watt rear hub motor. I have scoured the net and can not find any info on this rear hub motor. Hoping someone here might shed some light. There is no brand name , this is the only info on the hub motor guess it might be a model & serial number.
SYX236700CTD0297S1.
Thanks
I'm no expert but there are some Bafang/8fun motors with the SYX prefix but the flanges on your's (I'm assuming that was your youtube video) with the square sawtooth pattern is a bit unique. Suzhou Shengyi Motor Co has a few they list as DGWX type that look similar to that sawtooth pattern.
Thank you PDXzap,
You got a lot farther than I did. I'm curious on the motor because the description on the site which stated 11.4ah Samsung batteries, but received 10.4ah and not sure if they are Samsung batteries. Also Shimano tourney derailer but received the Altus. I want to make sure its a 350watt motor and I feel a drag when I stop peddling. How does someone know if its a 250watt or 350watt?
Timpo replied while I was typing my response:
The only way I know to verify the battery cells would be to disassemble the pack.
...I feel a drag when I stop peddling.
Are the brakes rubbing? Does it slow down substantially while coasting?
I can think of a few ways to measure the watts the motor is getting but none would be particularly easy. Put it on a dynamometer which you probably don't have or disconnect the wires powering the motor and measure the volts and amperage while running.
Thank you Timpo for the response,
Kent Intl told me to return that bike since the battery had damage and a part was missing from shipping. But then I ordered and received this bike which is the one I'm inquiring about the Hub motor.
There is discrepancies on the description which is why I'm looking into other areas. Wife really enjoys it , rides really smooth and quiet for the value.
After doing some adjusting all is good no brakes rubbing. Everything seems to be in order no dragging on front or rear wheels. I Just notice a slight drag when the motor stops and motor and battery never warm.
I would expect it's a geared motor. You can check it very quickly. A geared motor has a lot more resistance when rotated backward because now you're turning the motor via its gears and a clutch. Rotated forward, the motor freewheels because of the clutch, but there's the drag of the clutch. If you were to turn the axle with your fingers, it's difficult. Mounted on the bike, with tire/rim providing some rotational inertia, a spin of the wheel might have it go 10-15 seconds, vs over a minute for a regular bike wheel.
If you can feel that level of drag when riding, you're pretty good.
Kent's popup legal disclaimer says the actual specs may be different, not their fault. My translation anyway.
I bought a Kent Fat bike new for $99 several years ago. Made it into an electric fatbike. The only part that's still original is the frame, seat post, and the chain.
Thank you Thomas,
You are right there is a lot more resistance rotating backwards I really appreciate your response.
SYX2 motor 36V 700c wheel?
I know this is an old post, but you just helped me identify my motor for my Ride1Up 700 Series. It's only got the code "SY2248700CUL3030PS1" stamped on the housing. Nothing else is written on the motor. From what you mention, I now know I have a 22A 48V motor on a 700C wheel.
sn starting with SY is ShengYi motor company
Good luck getting anyone to respond. Trying to get replacement motor for a customer bought a cheap Canadian Tire Junction Victoria-e ebike and cannot get anywhere.... bike gives a jolt on initial pedal then nothign. no error codes as there should be, no service manuals, no documentation - I hate dealing with junk like this.
Good luck getting anyone to respond. Trying to get replacement motor for a customer bought a cheap Canadian Tire Junction Victoria-e ebike and cannot get anywhere.... bike gives a jolt on initial pedal then nothign. no error codes as there should be, no service manuals, no documentation - I hate dealing with unknown junk like this - stick with bafang people!!!!
How silly. Please find us repair parts for BBS01 and BBS02 A versions. Nearly a 20 year history of producing motors. And Bafang?
Both started in 2003.
next you’ll tell us eBikes.ca, Grin, sells unknown junk. https://ebikes.ca/product-info/grin-kits/shengyi-sx-geared-hubs.html
follow the link above for more...
The SX1 and SX2 are medium-sized front and rear geared motors from Shengyi that we stock as a 'slightly bigger brother' to the Bafang G310/G311 motors. These also have helical cut gears for silent operation, but they run an outrunner motor with a single stage planetary gear reduction rather than an inrunner with doublestage planets. This makes them a bit larger and heavier than the G31X hubs, providing higher torque output before overheating and more robustness at fast RPM's without risk of magnet adhesive failure.
Key Features​
  • Totally Silent Drive: The helical cut gear system of the SX1 and SX2 motors has the same "smooth as silk" feeling that you've gotten used to with the Bafang G3XX series or any direct drive hub motor.
  • Freewheeling: The SX motors currently in stock at Grin have a built in clutch so that they freewheel with no drag when unpowered, making them well suited for people who expect to ride frequently without any assistance.
  • End Cable Exit with Axle Flats: Although we prefer side cable exits when possible, at least the small diameter Z910 connector allows torque arms and axle hardware to slide over the cable side axle. The conventional M12 axle with 10mm flats allows the motor to be compatible with our standard lineup of front and rear torque arms.
  • Easy Disassembly: The Shengyi motors come apart easily for service using T20 torx bits, and features an O ring seal on the side plate joint for consistent waterproofing.
  • Medium Power Levels: This motor is ideal when you need a lightweight geared motor for somewhat higher power or speed levels than the Bafang G31X's, but don't need to go as far as the more expensive eZee or GMAC motors.
  • Combined Speed and Temperature Sensor: These motors were custom made with a combined speed + thermistor signal on the white wire of the Z910 motor cable. When paired with our Baserunner_Z9 controllers and a CA3-WP device this gives both bicycle speed readings and motor temperature readout with no extra wiring. The built-in temperature sensing means you never have to worry about overheating the motor on long hill climbs, it can automatically rollback power to stay in a safe zone.
  • Disk Compatibility: Both the SX1 (front) and SX2 (rear) motors have space for a 6 bolt disk rotor with correct rotor alignment on standard bike frames.
  • Cassette Freehub: The SX2 motor uses a Shimano compatible cassette freehub body , allowing it to run on modern bicycle drivetrains with 9, 10, and even 11 speed Shimano mountain bike cassettes. (Note that 11 speed Shimano road cassettes are not compatible as they require a longer freehub body).
Power Level and Winding Options​
Bafang G310 vs Shengyi SX2
We put these motors in the nominal 250-500 watt power class, but because they have a built-in thermistor and feature a robust outrunner motor design it is possible to run them safely at higher power levels and have the system rollback before the inside gets hot. We have not yet completed thermal testing in the wind tunnel in order to accurately predict the overheat time frames at different output torque levels, but you can assume that it somewhere in between the G31x and the really high-torque GMAC.
We stock the motors in 2 different winding options, a fast wind (6T, 9.8 rpm/V) intended for 20" wheels, and a standard wind (8T, 7.4 rpm/V) that is commonly used 26"/700c builds. With this combination of winding choice and wheel diameter, you will achieve cruising speeds of 30-35 kph with 36V battery packs and 40-45 kph with 48V/52V packs. For exact performance details with any combination of wheel size, battery voltage, and motor winding please have a look at our motor simulator page (Simulate Standard Wind, Simulate ast wind)
Bicycle Fitment, Axle Hardware, and Torque Arms​
Tabbed Washer Location
These motors have a natural fit for standard quick release bicycle frames that have 100mm front fork spacing or 135mm rear spacing. The front axle is exactly 100mm long while the rear is 136.5mm so no frame spreading is required, and the smallish diameter and narrow motor construction means that there are few fitment issues with the the rear stays or fork blades. The axle itself is the common M12 x 1.25 with 10mm flats, and it may be necessary to file open the dropout slot to the full 10mm width if it is too narrow.
Both the front and rear motors have internal tabbed washers on the axle shoulder which must be located on the axle inside the dropout for correct axle length and disk / cassette alignment. The tab faces outwards and into the dropout slot to provide additional anti-rotation strength. This solution is adequate on bicycles with strong chromoloy dropouts, but for alloy or thinner steel dropouts we always recommend a torque arm as well. Our standard V2 and V3 torque arms are recommended with the front SX1 motor, while the V4 torque arm is usually the best choice for the rear SX2 hub.
Internal Construction​
The SX1 and SX2 motors have a 15 pole pair outrunner motor driving a single stage planetary gear with a 4.8:1 reduction to the hub shell. The spur gears have a helical cut on them for minimal noise and vibration. Unlike most other helical motors that use thrust bearings for the axial forces caused by spiral gears, the SX hubs use double deep-groove ball bearings instead. This means in principle it will be possible to have a locked clutch version of the SX motor that is capable of regenerative braking and reverse mode like we have done with the GMAC motor.
Disassembled image of SX motor
Wiring and Connector​
Z910 HiGo Plug PinoutThese motor cable exits the end of the axle and extends 22cm to an overmolded Z910 connector terminal. While we prefer side cable exits, at least with the Z910 connector it is no problem to fit torque arms and axle hardware over the connector and cable and onto the axle. The exact hall mapping used by Shengyi is not the same as Bafang motors and so a controller that works with Bafang may not be plug-and-play with our SX1/SX2 hubs. We supply this motor as a kit either a Baserunner (recommended) or Phaserunner controller which has programmable hall mapping so this is not an issue, but we cannot guarantee compatibility with any 3rd party motor controllers.
The extra white signal wire is used for the combined hall and speedometer. The signal has a 10K Beta 3450 thermistor wired in parallel with a speedo pulse that toggles to 0V 6 times per revolution. The Baserunner_Z9 controllers automatically split this combined signal into separate speed and temperature lines to the CA3-WP device.
Disk Brake Compatibility​
Disk Rotor Mounting HolesBoth the SX2 and SX2 motors have the mounting holes for a 6-bolt ISO disk rotor with nearly correct offset for rotor alignment as long as the tabbed washer is included inside the dropout. The hubs are all shipped with a plastic spacer in place of a disk rotor so that the disk bolts can stay in place and at the correct depth. If you are installing a disk rotor, simply remove the plastic spacer and replace it with your ISO disk rotor, reusing the M5 bolts that came with the hub. If you are using other disk bolts be sure that they are no longer than 10mm. Bolts that are too long risk protruding inside the motor shell and scraping against the clutch.
Technical Specifications​
Standard (8T)Fast (6T)
kV7.4 rpm/V9.8 rpm/V
Phase to Phase Resistance119 mΩ72 mΩ
Phase to Phase Inducatance180 uH115 uH
Hysteresis Torque 0.44 Nm
Eddie Current Torque 0.009 Nm/(Rad/sec)
Spoke Flange Diameter 141 mm
Flange Spacing 38 mm
Axle Length100 mm (front) / 136.5mm (rear)
Motor Magnetic Pole Pairs15 Pole Pair, Outrunner
Gear Ratio4.78 : 1 (86T ring, 18T sun)
Effective Pole Pairs (for Baserunner)72
Output CableZ910 Connector, 22cm cable length
Thermistor10K NTC, 3450 Beta. Parallel with speed signal
Motor Weight 2.95 kg (front) 3.18 kg (rear)
Key Features​
Hysteresis Torque0.44 Nm
Eddie Current Torque0.009 Nm/(Rad/sec)
Spoke Flange Diameter141 mm
Flange Spacing38 mm
Motor Weight2.95 kg (front) 3.18 kg (rear)
Someone expressing anger and frustration over lack of support or parts is hardly silly. Fair enough, i amended and took out "unknown" - so it's known junk - cannot find parts for shengyi. nobody responds and unfortunately I don't speak Mandarin. Grin does not sell parts for them either as far as i can tell.. Grin sells 2 hub motors only. this is a shengyi mid drive. cannot find it anywhere. Factory does not respond,. Terrible company. At least Bafang is popular enough you could find a replacement motor, or a used one to strip parts off. my customer is stuck with a brand new bike that is a total loss because you cannot buy a replacement motor or parts.
AliExpress
EUNORAU EBIKE ONLINE SHOP-2 Store​
or build an alternative motor using old rim, or new complete wheel and motor. I’d quit offering repairs if not able to fix a customers ebike. Customer is responsible for the purchase of a cheap build. And should expect the repair cost. Measure the motor specs and buy a matching motor and switch out internals. You have a number of options.
nope. no shengyi mid drive motors or parts available on aliexpress or eunorau. If a company is going to put out a product, they should support it.
