Exacte, but it should be documented.I'm assuming this is because it assumes that the brake lever is pulled if the break is broken. for the same reason if you pull the brake it will disengage the motor
Alredy done. That is not the point. The bicycles are still under warranty, they are 3 monts old. BTW. the head office for IGO is 10k from my house and they dont even answer the door. It is a good thing I’m good with tools and can fix things but hat happens with people who are not manually inclined?Things are more expensive in Canada, I used to buy these from China for under $12 shipped. Look around for something that matches your connectors.
Amazon.ca link
