rudymsmith
My Raleigh Motus with Bosch Purion display also reads the speed about 10% high but the odometer seems to be as accurate as my car, motorhome and GPS display. I have also doubled checked distance with the measurement tool on Google Earth on PC. Speed inaccuracy means absolutely nothing at all on a bicycle but the odometer does play a role in battery calculations. I just don't understand why, once you have calculated discrepancy, it should be a problem other than to anyone who has OCD tendencies and, having family members who are OCD 'sufferers', I can appreciate their frustration. They can't help it and nothing you can do will alter the fact that everything has to be perfect, as they see it. As for Bosch conspiracy theories, well, what do they gain. My ebike is UK spec which means assistance should cut out at 15.5mph, roughly 17mph indicated taking in the 10% discrepancy yet, it doesn't. Mine seems to be 'faulty', in that assistance seems to cease at about 22mph (indicated) 20mph actual. This seems to be in common with many other Motus owners so I fail to see, even with the high readings, what any form of conspiracy could be seen in this. The high assistance cut out isn't something I'm likely to complain about, same as others in the same situation. If the odometer is accurate, the motor assists to at least 15.5mph (actual), the speedometer is within the 10% high legal tolerance then where is the cause for complaint?
People tend to miss the point of this thread entirely - which is - If manufacturers ADVERTISE 28MPH before a class III motor stops assisting, then it should do just that - 28 MPH before dropping out. I've ridden bikes all my life, motorcycles, cars etc... ad nauseum, and what I want is simple: TRUTH IN ADVERTISING! If they were honest and said the motor cuts out at 26.5 mph, oh well, I'm good with that. Just don't lie to me to beef up your sales or make me think your battery or motor is better than your competitions or to be on the safe side of government oversight. The current overestimate of speed v. motor assist is software driven.. period, yes you can fiddle with tire size and magnet location etc... but as manufactured, and sold, the software used by my 3 Bosch E bikes, all class III's, is wrongly optimistic (for whatever reason) it is incorrect and the faster you go the more incorrect it becomes.
