Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
Several Vado 5.0 (Speed version) Fixes and Modifications After 2 Years of Use
My brother Jacek did a great job as of today on my "big" Vado:
I finally got my third Specialized 604 W Vado/Como battery. The price was approximately US$1,230 (we pay VAT in Europe). The battery cover is so-called Satin. In fact, it is somewhat Navy Blue. I don't care: I will be able to identify my three batteries easily: Gray, Black/Gray, Navy Blue The way to make a double metric century is open for me!
@Rider51, @Brendon@TBSM: Do you think a new battery is in some "hibernated" state and could be stored for say 1 year unused until it were charged for the first time?
- Repairing the STOP indicator switch in a TRP Zurich brake lever
- Lowering the stem as much as possible
- Fixing the number plate support at the rear fender
- Swapping the tyres for Schwalbe Marathon Winter Plus 50-622.
- Tektro Racing Products (TRP) is using a reed switch (at the left) to activate the STOP indicator whenever you depress the Zurich brake lever. The lever moves a permanent magnet that closes the contacts of the reed switch. As you can see, the signal wire was broken. It took Jacek quite a while to use a piece of his own wire to solder, insulate, and place the brake sensor back in the place (it was for the left brake lever).
- Two years ago I used a 75 mm stem riser to raise the Vado stem for a more upright riding position. Two years of cycling teaches you a lot. I was experiencing sore butt on any long ride! It was because almost all my body weight was resting on the saddle. Quite recently, I was researching the possibilities for more aero riding position on my Vado SL. It was because the VSL as a low power e-bike has been very susceptible to headwind, and my torso was acting as an air drag brake. Following advice of fellow EBR Forum members, I lowered the VSL stem as low as possible, and I even slammed the Redshift ShockStop stem into -6 deg position! To find out the sporty (forward) riding position was quite comfortable, and a big part of my body weight was shifted on the handlebars. My sore backside issues became the matter of the past!
 Following the suit, I asked my brother to totally remove the stem riser on my Vado 5.0, and place the stem as low as possible (with replacing the main bolt with a shorter one). It worked!
- Jacek has fixed the attachment of the number plate holder to the rear fender. It was the last time to do it!
- And he has swapped the tyres for winter ones.
