Hi Everyone, I've been stalking these forums for a while as I waited for my bike to show up!
After it finally arrived last week, I set it all up with the Nyon 2021, but have a problem connecting to WiFi. It works fine with the Bluetooth connection and it’s paired to the phone fine.
My WiFi network has a long name, and a full 63 character pass phrase, using WPA2, operating on both 2.4GHz and 5GHz bands. When searching for WiFi Networks it doesn’t appear in the list discovery list on the Nyon.
I attempted to manually add the network, on the first attempt, after entering the wifi SSID and password, the Nyon displayed the name in the list and showed connecting, it failed with incorrect password.
After this the behaviour of the Nyon changed. Notably the added network doesn’t appear in the list of saved networks. Furthermore, when I attempt to add it again, nothing happens, as in after I select add network enter the network SSID and password, it simply goes to back the discovered WiFi list. It doesn’t show any attempt to connect or acknowledges the entry.
It connects fine to phone's hotspot, just not the home wifi.
Any ideas?
NoobNoob
— Edit: Solved.
Nyon doesn’t support 2.4GHz channel 13. If you are having trouble connecting to your WiFi, check if your WiFi is operating on channel 13 and change if it does.
Any ideas?
NoobNoob
— Edit: Solved.
