Cramer Long
- USA
Stephan Mikes I thought it easier to comment here vs trying to communicate a conversation of Youtube . Thanks for answering though . I just asked the wrong question :
I have looked thru the majority of Riser and Steering Tube Extender Threads. I'm posted in the Specialized Section because my question pertains to Vados . The ones with the Specialized stem that carries the light Bracket on the faceplate .
If I put an Aftermarket Stem on . Is there anyway I can use the OEM faceplate on the aftermarket stem? I assume since it's 2 separate clamps I can. I know I can buy a steering tube extension to raise my bars . Which is all I really want to do . It just looks so cobbled to use the delta tube extension . The Satori one would look better . Although the one it appears they offer is a tad to high for the Stem setup on the Vado.
I know that Specialized offers a Stem that has the light bracket .
Like I said earlier I've read thru the majority of Stem Type Threads . I also see where someone else asked about using the Stock OEM faceplate with another companies stem. And nobody answered it . Yet I see pictures where they are using their lights in the same area off the stem. So I assume you can use the Oem faceplate on certain Aftermarket stems . Just trying to confirm that is true ? Has anyone done so ? Thanks much
