The latest American electric bicycle brand (Slinker){For The Emerging Future}www.slinkerbikes.com
Sleek eBikes
37 Main St, Tarrytown, NY 10591, United StatesTarrytown 10591United States
+1 914-909-1790
[email protected]
Love life, love riding
it’s not a bad looking bike, but agree with others, tires ad tubes are wear items that need to be available from multiple sources, not solely the manufacturer. ppl don’t want to wait a week or more for a tube. tires and tubes should be commodities, not proprietary. it’s bad enough the lack of choice in 20 x 4 and 20 x 3 tires. can’t imagine only ONE tube or tire works for your bike.
We have sufficient spare parts inventory (including tires, motors, digital meters and controllers, etc.), so we not only sell products, but also allow customers to get perfect after-sales service.
www.lemeego.com
Looking for long-term partners. Reasonable warehouse wholesale price. The warehouse is located in Dallas
Please note that the world's first all-terrain dual-drive folding electric bicycle is coming.
We call this dual-drive ebike an all-terrain product. Compared with general single-drive commuter products, our products have increased playability. The three modes of front drive, rear drive and dual drive can be switched freely via the button. 1. When running in front-drive mode alone, the product enters the power saving mode, which greatly increases the endurance distance and is suitable for riding on flat roads. 2. When running in rear-drive mode alone, the torque will increase slightly, which is suitable for riding on beach, grass or gravel roads. 3. When the dual-drive mode is running, the two motors work at the same time, and the torque reaches 70N/M. The amazing torque allows the rider to easily climb hills of more than 40 degrees. This mode is suitable for pulling heavy objects or mountain cross-country use.
Slinker-Mini
BATTERY PACK:SEAT POST VERSION,36V10.5AH / 378WH (LG 3500mAh CELLS)
BATTERY CHARGER:D-POWER 48V 2A
MOTOR:MXUS 350W(Rated Power) Geared Brushless Motor
CONTROLLER:KT 36V15A
LCD:KT LCD-5
SENSOR:KT-V12 Double Hall Speed Sensor
TOP SPEED:16MPH
RANGE:30 Miles
COLOR:Midnight Black, Metallic Grey
FRAME:Aluminum-Alloy 6061, 16 in. Foldable
FORK:Alloy Fork(No Suspension)
HANDLE BAR:22.2*31.8*640mmL, 3.0mm,6°
HAND GRIP:Velo VLG-1505D2 130/130mm
STEM:Standard Folding Stem
HEADSET:Aluminum with Bearing, 28.6*56-56*30/39.8 H:14mm
WHEEL:36 Hole Spoke Wheel with Double Wall Rim
TIRES:CST 16*2.125
CRANKSET:Prowheel PRO-552PP-1, Steel Ring with Plastic Cover, 52T, all Black
BOTTOM BRACKET:BB68,122.5mm=26.5+68+28
CHAIN:KMC X11 R, High Performace Chain
REAR DERAILLEUR:Meego 4 Speed, 11/13/15/18T
CASSETTE:Meego 4 Speed kit
SHIFTER:Meego 4 Speed kit
BRAKE SYSTEM:JAK Mechanic Disk Brake
FRONT LIGHT:STAR UNION QD-139/48V
REAR LIGHT:AA Battery Red Light
SEAT CLAMP:Single Lock Clamp
FENDERS:Steel, Painted To Black
NET WEIGHT:46lbs(21kg)
PACKAGE WEIGHT:55lbs(25kg)
PACKING SIZE:140cm*28cm*64cm
The products are about to arrive in our US warehouse, limited time and limited purchase.
Slinker (Lindie) front and rear mudguard installation diagram.
That beauty is screaming for a tan leather seat to accent the grips and tires! Very nice looking. :)
Thanks @theemartymac and I agree. The owner is about 4'11" and may go with a wider gel saddle. Even the battery leads are through frame. The goal was a clean build in the USA.
Or should I make it a 20" folder with a 250W hub? And add a bunch of connectors to the HB?
Slinker is the folding electric bicycle specialist. All of our bikes are folding and will remain so. The folding is anchored in the brand's DNA. The challenge was to design electric bikes that were easy to transport. Indeed, with the battery, the engine and the components an eBike can quickly become heavy and bulky. Today we are happy to have provided an answer to these problems with our range of light and ultra compact electric bikes.
www.slinkerbiels.com
I find the proliferation of cheap mini fat bikes 🚲 concerning. I’m thinking there will be issues with their parts stream 🙈
Slinker---Chu'mana
  • Competitively priced with high-end components
  • LG Li-on 36V 350W battery
  • Shimano 7-Speed Cassette and Shifter
  • 350W Mxus Rear Brushless Motor
  • Front and rear spring suspension providing the optimal comfortable riding experience
  • Battery is uniquely hidden in the seat post
  • The seat post is removable for easy charging
  • Charging port under the seat
  • Charging time is only 5 hours
  • Battery allows for maximum distance of 40 miles on one charge
  • LG is reputable high end battery brand well known to the common consumer
  • 350W Mxus Geared Brushless Rear Motor
  • Rated 350W Mxus motor allows for smooth acceleration
  • Top Speed of 20 miles per a hour
  • Allows to handle many surfaces from road riding, to beach, forests and can handle inclines with ease
  • Slinker ability to fold allow for easy portability and storage, whether at the office, at home or for a weekend getaway
  • Slinker adjustable seat post fits any rider from 5’ to 6’7” as a one size fits all e-bike
  • Slinker double seat post clamps ensure safety and zero slippage. While the seat post also features a unique locking system to ensure the battery cannot be stolen.
  • Slinker Chu’Mana features 36 spoke wheel with Double Wall Rim for stability.
  • Star Union front headlight provides optimal brightness to ensure safety and a mind easing comfort for night riding ensuring you will always be recognized.
  • USB port for phone charging while riding
  • JAK Mechanical disc brakes provides optimal breaking time and smoothness while putting rider safety first.
  • Arrives pre-assembled
  • 5 Level Pedal Assist
