Me again! The pedal assist stopped working on my BBS02 after only 2 days of riding. I have looked through other forums, and I understand that I probably need to open the motor and check the controller wires, but before I go taking my bike apart again, I wanted to double check to see if anyone else knew of something I may not be considering.
Here are the facts:
1. The throttle assist works fine
2. The brake sensors work fine (I installed brake sensors on my existing disc brakes)
3. I have disconnected and reconnected all of the wires that I can see multiple times.
4. I have powered off and removed the battery and reinstalled it.
5. I have turned the LCD screen and turned it back on several times, and gone through all of the settings to see if I had somehow turned pedal assist off. There's a slight possibility that I am missing something there, but I don't think I am. There is no indication that you can turn pedal assist off.
6. The speed sensors appear to work fine. It showing my speed when I am moving, and the red light goes off when the battery piece on the spoke passes the sensor.
It could be good for me to open the controller and learn about that, but I just wanted to see if there were any other ideas out there before I do that.
Cheers!
			Here are the facts:
Cheers!
